ASCII Number to Integer or Long Integer or Hex Number
rrb011270
View user's profile Send private message Yahoo Messenger
PostPosted: Fri Oct 15, 2004 7:52 am     Reply with quote
Hello der,
The code snippet in this topic will convert an ASCII number serial stream into an interger, or long integer or a Hex formatted number.
// convert ascii number string to integer number
unsigned int8 asciiNum2Int(unsigned int8 index)
   unsigned int8 n;
   n = RXbuffer[index];
   if ((n<='9')&&(n>='0'))
      return (n&0x0F);     // Pure number 0 to 9
   if ((n<='F')&&(n>='A'))
      return ((n&0x0F)+9); // Hex nnumber A to F
   if ((n<='f')&&(n>='a'))
      return ((n&0x0F)+9); // Hex in lower case
   return (0);
// convert ascii number to interger number
unsigned int8 ascii2int8(unsigned int8 indx)
   unsigned int8 cnvt=0;
   cnvt = (asciiNum2Int(indx)*10) + asciiNum2Int(indx+1);
   return(cnvt);
// convert ascii hex number to long integer number
unsigned int16 asciiHex2int16(unsigned int8 indx)
   unsigned int16 addr=0;
   addr = ((asciiNum2Int(indx))*4096) + ((asciiNum2Int(indx+1))*256) +
          (asciiNum2Int(indx+2)*16) + asciiNum2Int(indx+3);
   return(addr);
Hope this would be of great help to any PIC user.
panayig
PostPosted: Fri Oct 15, 2004 10:18 am     Reply with quote
Since I requested this code from you I have to thank you here in public for your responce. Thank you rrb011270 for your help and your patience.
And I have to thank also all of you that you are so kind to answer to questions and to help other people that you dont know.
I am involved in a project and I have to learn about programming PIC the hard way that is asap. Without this forum I would have half the knowledge I have now.
I hope that one day I will be able to contribute to this forum as you all do.
Once again thank you rrb011270. Very Happy
USss
About int32
PostPosted: Fri Oct 22, 2004 10:05 am     Reply with quote
Help me with unsigned int32.
