jptalledo Guest
Help with Rs232 and putc |
Posted: Tue Oct 26, 2004 11:44 am |
Hi everyone
I have trouble with this code, I received in my pc the data 0xFF 0x80 0xFF but I send 0xFF 0x00 0xFF .what is wrong. I use ccs 3.2 compiler
#include "C:\servo1.h"
#include <stdio.h>
#include <string.h>
setup_adc_ports(ALL_ANALOG);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
putc(0xFF);
delay_us(10);
putc(0x00);
delay_us(10);
putc(0xFF);
Posted: Tue Oct 26, 2004 11:52 am |
You need to post the first part of your program, such as
the #include statement for your .H file, and #fuses,
#use delay(), and #use rs232(), etc.
Also post the PIC that you are using and the FULL version number.
(ie., not "3.2", but 3.207, or 3.212, etc.) |
SherpaDoug
Posted: Tue Oct 26, 2004 12:02 pm |
It looks like some sort of framing error. It could be inaccurate clocks giving inaccurate baud rates. _________________ The search for better is endless. Instead simply find very good and get the job done. |
jptalledo Guest
code listing |
#include <16F876A.h>
#device adc=8
#fuses NOWDT,HS, PUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#include <stdio.h>
#include <string.h>
setup_spi(FALSE);
setup_vref(FALSE);
putc(0xFF);
delay_us(10);
putc(0x00);
delay_us(10);
putc(0xFF);
// delay_ms(500);
// putc(0xFF);
// putc(0x00);
// putc(0x00);
my compiler version is 3.203 |
asmallri
Posted: Wed Oct 27, 2004 8:06 am |
Are you using a Max232 chip? If so check the +V and -V voltage generated on the chip. They should be about +9.5v and -9.5v respectively. If not look for a capacitor installed incorrectly or a poor solder joint. This is a very common source of problems.
How are you powering the target? How is the ground connection commoned between the two systems? |
