Pic ethernet isa protocol
mjdale2003
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Sun Oct 10, 2004 1:41 pm     Reply with quote
Hi
I am currently haveing trouble geting my project of the ground, i wish to ethernet enable a pic and am useing a d-link de200e isa board i know enough about the protoals tcp, ip, udp so on ,but i cant find any data published on the net about controling the board its self does anyone have any info as i would very greatfull. I have searched the forum and found some data on the ne2000 protocol whould that work?
Regards
Michael
Mark
PostPosted: Sun Oct 10, 2004 3:12 pm     Reply with quote
A few links for you:
http://www.kinninmonth.freeserve.co.uk/jb.htm
http://www.edcheung.com/awards/pic2k/code.htm
You are going to need a stack. Microchip has one and it has been ported to CCS. This board will work with that stack
http://www.compsys1.com/workbench/uWEB/uweb.html
There is a schematic so if you want to create your own board, here is where you can get some of the stuff:
http://www.remostech.com/tcpip-chips.html
rnielsen
PostPosted: Mon Oct 11, 2004 8:26 am     Reply with quote
Try going to www.lantronix.com and look at the Xport. This is a very small device that can network-enable a device that has a serial port. I've used it in several projects and it has been quite reliable. It is designed to be PCB mounted and runs off 3.3V.
Ronald
treitmey
PostPosted: Mon Oct 11, 2004 2:07 pm     Reply with quote
Yes,.. Xport is the way to go for a small project.
