arun Guest
Problem with MCP 3208 using the standard driver |
Posted: Sat Oct 09, 2004 12:02 pm |
I have used the standard driver file MCP3208.c that comes with CCS C compiler package to access the ADC. Although the ADC reads accurately,
I find that it is not able to read changing voltages. Here is a sample of the data read ( all values are in volts, Time span between samples are 581 Milliseconds).
0.1933594
0.2285156
0.2109375
0.2109375
0.2109375
0.1933594
0.1757813
0.1582031
0.1582031
0.140625
0.140625
0.140625
0.1230469
0.1230469
0.1230469
0.1230469
0.1230469
0.1054688
0.1054688
0.1054688
0.1054688
The same voltages are read quite accurately by a PIC 16F877 mcu.
Kindly advise wether the driver code is OK or does it need any changes in delays.
thanks
arun |
Humberto
Posted: Sat Oct 09, 2004 4:00 pm |
Pls could you descibe a little more what the problem is?
Also post the relevant functions calls and delays involved, and a small desciption
of the hardware regarding the analog input, it seems like an capacitive input.
regards,
Humberto |
Re: Problem with MCP 3208 using the standard driver |
Posted: Mon Oct 11, 2004 10:46 am |
arun wrote: | Hi,
0.1933594
0.2285156
0.2109375
0.2109375
0.2109375
0.1933594
0.1757813
0.1582031
0.1582031
0.140625
0.140625
0.140625
0.1230469
0.1230469
0.1230469
0.1230469
0.1230469
0.1054688
0.1054688
0.1054688
0.1054688
thanks
arun |
The most likely problem is that your voltage source actually has significant high frequency noise. The MCP, will take a reading in just 1.5 clock cycles of the chip. The PIC, instead has a much larger capacitor, and takes typically more than twenty times as long to actually acquire a voltage. The internal capacitance used in the MCP, is just 20pF, in series with a 1K switch resistance, against the PIC, having 120pF, in series with about 8K for the switch resistance and other losses. About a 50* change in the maximum frequency that can be recorded...
It is also pointless to display 6 digits (and could well mislead you as to the real 'accuracy'), when the chips only support 12bit accuracy.
The MCP, is _better_ at reading changing voltages than the PIC, but can easily show problems with the voltage source, the reference source, and the board layout itself, that the PIC will not register.
