How to inform the compiler for a bootloader?
Boyko
PostPosted: Mon Oct 11, 2004 5:57 am     Reply with quote
Hi.
I'm a begginer with the CCS C.
Till now I used Pibasic pro and Proton+. When I want to tell the compiler that I'll load the HEX file into the PIC with a bootloader I only have to type:
Define loader_used 1 --> for PBP
Bootloader = 1 --> for Proton+
Now I have the CCS compiler, but I don't know what line I've to type to inform the compiler for the bootloader. My PIC is 18F452 and I intend to use the microcode loader.
Any help will be greatly appreciated.
Regards
Boyko
dvsoft
PostPosted: Mon Oct 11, 2004 6:55 am     Reply with quote
bonjour
that depend of your bootloader
reserver is needed place in ROM for the code of the bootloader and to indicate the new location of the reset
// BootLoader
#build(reset=0x200, interrupt=0x208)
#org  0x0000,0x01FF             // BootLoader Rom location
void bootloader()
    #asm
    nop
    #endasm
I use the following code with my bootloader
Boyko
PostPosted: Tue Oct 12, 2004 7:31 am     Reply with quote
Please help. I don't know what's wrong. I'm loading the HEX file with the Microcode loader, but the program doesn't work (i.e. the LED does not blink). Here it is the code:
#include <18F452.h>
#define led PIN_D0
// BootLoader
#build(reset=0x200)
#build(interrupt=0x208)
#org 0x0000,0x01ff
void bootloader()
   #asm
   nop
   #endasm
main() {
   while(1==1) {
      output_low(led);
      output_high(led);
What I have to do?
Regards
Boyko
PostPosted: Tue Oct 12, 2004 7:48 am     Reply with quote
you are missing all the fuses. When you you the wizard it sets them up for you. If you do it manually then you have to do it yourself
something like
#fuses NOWDT, NOLVP, H4 ......,
do a search on #fuses
Boyko
PostPosted: Tue Oct 12, 2004 11:52 am     Reply with quote
Nope. This is not the problem. I've added the following line:
#fuses XT,NOPROTECT,NOLVP,NOWDT
but the led still does not blink.
May be the reset and interrupt vectors must be different?
Regards
Boyko
PostPosted: Tue Oct 12, 2004 11:57 am     Reply with quote
You keep referring to a bootloader which you call a "microcode loader".
What company makes this bootloader ? Can you post a link to their
website. If we know more about the bootloader, then we can possibly
tell you how to make it work with CCS.
Boyko
PostPosted: Tue Oct 12, 2004 12:08 pm     Reply with quote
Microcode loader is a part from the Microcode studio, which is the IDE for Picbasic pro.
Here it is the link for the Microcode loader part:
http://www.mecanique.co.uk/code-studio/loader/index.html
I can send you the microcode loader if it helps.
Regards
Boyko
PostPosted: Tue Oct 12, 2004 12:43 pm     Reply with quote
I read their page. This bootloader sounds very much like the
one from http://www.microchipc.com, because they mention
relocating the first 4 words of ROM.
In that case, the following code should work. You don't need to
use the #build directive.
When you initially program the "pre-compiled HEX file" into
your 18F452, make sure that you check the Config bit settings.
Make sure that it's set for XT, and that Watchdog and LVP are Disabled.
It also would help if Brownout and Power-up Timer are enabled.
The #fuse line shown in the application program below
actually won't be programmed into the PIC. The Config
bit settings used are the ones in the "pre-compiled HEX file"
(or the ones that you set in the PicStart-Plus Config Bits window).
#include <18F452.H>
#fuses XT, PUT, BROWNOUT, NOWDT, NOLVP
#define led PIN_D0
// Reserve the top 384 words (768 bytes) of ROM for the bootloader.
#org 0x7D00, 0x7FFF {}
main()
   output_low(led);
   output_high(led);
