ICD2 Guest
MAX195 16-bit A/D converter |
Posted: Sun Jun 13, 2004 2:46 pm |
Please help me to connect MAX195(16bit A/D 85k/s) via 18F1320 or other(don'n metter)
That is MAX:
function: 16Bit ADC 85Ksps
package: DIP/Wide SO/Ceramic SB,16
manufacturer: MAXIM
added-by: Dominic Plunkett
BP,UP,/SHDN | 1 16| VDDA
LK | 2 15| VSSA
SCLK | 3 14| AGND
VDDD | 4 13| AIN
DOUT | 5 12| REF
DGND | 6 11| VSSD
/EOC | 7 10| /RESET
/CS | 8 9| /CONV
This information was added by a third party and may be incorrect.
This pinout came from the Chipdir:
http://www.chipdir.org/ |
dyeatman
Interfacing a Maxim MAX195 to a PIC |
Posted: Sun Jun 13, 2004 3:07 pm |
This is not the place to get your school homework or research projects done for you, BUT we will try to help once you put forth an effort.
Specify/Decide what chip you are/will be using.
Resources available:
Maxim MAX195 Datsheet can be found here:
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1040
Maxim Application note here:
http://www.maxim-ic.com/appnotes.cfm/appnote_number/572
Application note for interfacing a similar Maxim ADC chip to a PIC is found here:
http://www.maxim-ic.com/appnotes.cfm/appnote_number/2394
Search this site for I2C code for examples to learn how to write a driver.
If you want help using a specific PIC and CCS C then we can likely help you. We will not write all your code for you but once you get some code written and have tested it then come back and show it to us and describe what problems you are encountering and we may be able to help you debug it.
Good Luck! |
ICD2 Guest
Thanks |
Posted: Tue Jun 15, 2004 4:26 pm |
Thanks program still not. |
Userrr
Start |
Posted: Thu Oct 07, 2004 10:29 am |
Start to write program, but with connection problem, please help
me understand how better connect max with PIC.
This this my:
http://www.icd2.front.ru/max195.jpg |
