question about PWM
Nick
question about PWM
PostPosted: Mon Oct 04, 2004 7:29 pm     Reply with quote
"20MHz crystal seems to be 1.22 KHz (per Microchip manual)" via a search.
So I downloaded the datasheet but I didnt see any type of refence chart with that data for 4mhz.
I want to get in the range of 10hz or so.
btw I have a 16f876
Nick
Haplo
PostPosted: Mon Oct 04, 2004 10:02 pm     Reply with quote
You have to use the formulas in the datasheet to calculate the minimum possible frequency. For a 4MHz crystal it would be about 240Hz.
If you need a 10Hz wave you'll need to implement it using Timer/Compare interrupts.
J_Purbrick
PostPosted: Tue Oct 05, 2004 11:04 pm     Reply with quote
"20MHz crystal seems to be 1.22 KHz (per Microchip manual)" was a quote from one of my postings! To get a complete sentence, it should have read something like, "The slowest PWM rate you can achieve with a 20MHz crystal seems to be 1.22 KHz (per Microchip manual)".
If you want to use the built-in PWM generator you'd have to run it with a ridiculously slow oscillator to get 10Hz. Better to do it in software.
