How many Stream's Can I Use?
bertronicom
PostPosted: Mon Oct 04, 2004 9:21 am     Reply with quote
How many diferent serial ports can be used by the way of Stream?
#use rs232(STREAM=HOST_id, baud=9600,parity=N,xmit=HOST_TX,rcv=HOST_RX,bits=8)
#use rs232(STREAM=BT_id, baud=9600,parity=N,xmit=BT_TX,rcv=BT_RX,bits=8)
I'm working with CCS last version, and I'm sucessfully work with 2 conections.
SherpaDoug
PostPosted: Mon Oct 04, 2004 10:34 am     Reply with quote
I am using three streams on a 16C771, but I suspect the only limits are RAM and ROM space. What chip are you using?
Haplo
PostPosted: Mon Oct 04, 2004 5:27 pm     Reply with quote
In theory, there are is limit to the number of streams you can use. As SherpaDoug said the limiting factor is the code space, and also availability of I/O pins (althoug you can define two different streams on the same pins).
I have used 4 without any problems.
bertronicom
RS232 Streams
PostPosted: Tue Oct 05, 2004 3:21 am     Reply with quote
Hello SherpaDoug, I'm using PIC18LF252 at 3.3volts.
I've configured two RS232 serial ports.
void main () {
fprintf( BT_id , "INQUIRY 5 NAME\n\r");
fprintf( HOST_id , "\n\rRx Comando: INQUIRY_NAME");
In this case de first fprintf works but not second.
void main () {
This code works.
Theoretically the first code would work żisn't so?
Hello Haplo, Are you saying you're multiplexing two pins to diferents RS232 conections?
It's working fine?
thanks everyone
treitmey
PostPosted: Tue Oct 05, 2004 8:42 am     Reply with quote
I think I do something like this too.
#use rs232(baud=38400,xmit=PIN_C4,INVERT,stream=DEBUG)
#use rs232(baud=38400,xmit=PIN_C4,INVERT,stream=STDERR) //
#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,stream=RS485)  // RS485 is the default
one is is STDERR and one is DEBUG,.. both to the same pins..
in therory I can take out debug,.. and leave STDERR.
Haplo
Re: RS232 Streams
PostPosted: Tue Oct 05, 2004 5:42 pm     Reply with quote
It's working fine?
Yes you can, and it works fine. Taken from one of my source files:
#use rs232(baud=4800 ,parity=N,xmit=PIN_C3,rcv=PIN_C2,enable=PIN_C1,bits=8,restart_wdt,stream=EUM1)
#use rs232(baud=1200 ,parity=N,xmit=PIN_C3,rcv=PIN_C2,enable=PIN_C1,bits=8,restart_wdt,stream=EUM2)
