How to write 16bit using WRITE_EXT_EEPROM( address, value );
PostPosted: Wed Oct 06, 2004 10:55 am     Reply with quote
hi there.
i'm currently looking on WRITE_EXT_EEPROM( address, value );
what i want to do is store 16bit value into my eeprom.how can i do that?.
mvaraujo
PostPosted: Wed Oct 06, 2004 11:28 am     Reply with quote
You can save two bytes in sequence! One in each address!
Humberto
PostPosted: Wed Oct 06, 2004 2:03 pm     Reply with quote
Saving each byte in sequences all you get is two consecutive bytes stored in external EEPROM,
to affect the whole number to be able to operate arithmetically you need to create a struct.
#define addr_varH              0x1000
#define addr_varL     addr_varH + 1
struct BigVar{
int8  varL;
int8  varH;
union store{
long  WordValue;
struct BigVar  double_var;
           }Stuff;
// to access a byte:
    varH = read_ext_eeprom(addr_varH);
    varL = read_ext_eeprom(addr_varL);
// to write a byte:
    write_ext_eeprom(addr_varH, Stuff.double_var.H);
    write_ext_eeprom(addr_varL, Stuff.double_var.L);
// to modify the whole number:
   WordValue += 1;
Best wishes,
Humberto
Haplo
PostPosted: Wed Oct 06, 2004 6:02 pm     Reply with quote
Also take a look at CCS' official FAQ on this subject...here:
http://www.ccsinfo.com/faq/?24
