Delene Mulley Guest
pic16c8452 and port a |
Posted: Sun Nov 18, 2001 4:16 am |
Please can someone help me I'm more than pulling my hair out.
I like just about everyone else, was using the f877 and have changed to the 18c452.
I use porta - a3 to calculate a value. If the line is high I add a value. This works fine on my f877 but i can't get the 452 to recognise the changes on the ports.
My code is
if (bit_tes(porta, 0))
total = total + 1;
I have also tried
if (input(pin_a0))
total = total + 1;
without any joy.
What am I missing???
Original Post ID: 1191 |
Eric Belanger Guest
Re: pic16c8452 and port a |
Posted: Sun Nov 18, 2001 12:13 pm |
I'm not sure if this may help, but did you disable the A/D converter? If not the default uses is analog input and not Digital IO.
// A/D Disable, PORT A I/Os Numeriques seulement
SETUP_ADC( ADC_OFF );
SETUP_ADC_PORTS( NO_ANALOGS );
Eric
:=Please can someone help me I'm more than pulling my hair out.
:=I like just about everyone else, was using the f877 and have changed to the 18c452.
:=I use porta - a3 to calculate a value. If the line is high I add a value. This works fine on my f877 but i can't get the 452 to recognise the changes on the ports.
:=My code is
:=if (bit_tes(porta, 0))
:= total = total + 1;
:=I have also tried
:=if (input(pin_a0))
:=without any joy.
:=What am I missing???
Original Post ID: 1200 |
Delene Mulley Guest
Posted: Mon Nov 19, 2001 1:24 am |
Eric you are a genuis
THANK YOU
:=Hi,
:=I'm not sure if this may help, but did you disable the A/D converter? If not the default uses is analog input and not Digital IO.
:= // A/D Disable, PORT A I/Os Numeriques seulement
:= SETUP_ADC( ADC_OFF );
:= SETUP_ADC_PORTS( NO_ANALOGS );
:= Eric
:=:=Please can someone help me I'm more than pulling my hair out.
:=:=I like just about everyone else, was using the f877 and have changed to the 18c452.
:=:=I use porta - a3 to calculate a value. If the line is high I add a value. This works fine on my f877 but i can't get the 452 to recognise the changes on the ports.
:=:=My code is
:=:=if (bit_tes(porta, 0))
:=:= total = total + 1;
:=:=I have also tried
:=:=if (input(pin_a0))
:=:=without any joy.
:=:=What am I missing???
Original Post ID: 1220 |
