16F877 "Not enough RAM for all variables" err but
cagacug
PostPosted: Wed Sep 29, 2004 7:17 am     Reply with quote
hi to all,
I am programing a little big program and having a sticky error which I could not manage to get rid of it. If you can give me some ideas I will be thankfull.
16f877
CCS 3.200
the xxx.h file
#include "D:\16F877.h"
#device ICD=TRUE
#device *=16
#device ADC=10
#fuses NOWDT,HS, PUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD, NOWRT, DEBUG
begin of main file
#include "D:\xxx.h"
#include "D:\2416.c"
#include "D:\ds1307.c"
#include "D:\ds1868.c"
#ZERO_RAM
have some pointers and a big array in RAM
   int *pram[8];              //vram variables
   int lcd_ram1[7][4],lcd_ram2[7][4],lcd_ram3[7][4],
       lcd_ram4[7][4],lcd_ram5[7][4],lcd_ram6[7][4],
       lcd_ram7[7][4],lcd_ram8[7][4];
and have a big table in rom of 1256bytes, so the page 3 is almost not usable!
    #ORG 0x1AFF, 0x1FFF {}
   #ROM 0x1AFF = {0,0,0,0,0,
I am using the interrupts TIMER0 and EXT,
I tried to add a function call(keyb_rx()) to the int EXT ISR and got the "not enough RAM..." error. When I move the function call to main I dont have this error. So this make me to think that interrupts calls need more blocks of ram. Also there is lots of var that I have to use global, speed is concerned so the big array up is 224bytes long. Some funny errors in mind I try to change place of code or delete up to 10 global variables temporarly but no success. May be I am pushing to hard but I dont understand wht it is working when the function is in main?
Here is the .sta file when compiled w success(when the "keyb_rx ()" function is in main)
ROM used: 5030 (61%)
          5505 (67%) including unused fragments
          3 Average locations per line
          9 Average locations per statement
RAM used: 287 (80%) at main() level
          313 (87%) worst case
Lines Stmts  %   Files
  916   478  82  D:\xxx.c
    9     0   0  D:\xxx.h
  260     0   0  D:\16F877.h
   88    23   2  D:\2416.c
  112    62   6  D:\ds1307.c
   63    22   2  D:\ds1868.c
 2896  1170 Total
Page ROM  %  RAM  Functions:
0     20   0   1  @delay_ms1
0     87   2   3  @I2C_READ_1_56_57_20000000
0     81   2   1  @I2C_WRITE_1_56_57_20000000
0     13   0   0  init_ext_eeprom
0    143   3   4  write_ds1307
0     25   0   3  @DIV88
0    166   3   6  read_ds1307
0     41   1   2  @MUL88
0     60   1   2  init_ds1307
0    111   2   8  set_pot
0     11   0   0  @const98
0    972  19  19  kol_kaydir_left
0     25   0   5  @MUL1616
0     11   0   0  @goto10262
1    881  18  17  kol_kaydir_right
1     11   0   0  @goto10356
0     80   2   8  load_data
1    368   7   4  keyb_rx
0      4   0   0  EXT_isr
2   1327  26   2  timer0_int
2      8   0   0  @goto10607
2     18   0   0  @goto10659
2     28   1   0  @goto10692
2     28   1   0  @goto10717
0      7   0   0  TMR0_isr
1    402   8   4  main
0     44   1   5  @DIV1616
 Segment   Used  Free
00000-00003     4  0
00004-00039    54  0
0003A-007FF  1901  89
00800-00FFF  1662  386
01000-017FF  1409  639
01800-01AFE     0  767
01AFF-01FFF     0  1281
Any diff idea?? Question
Thanks, Laughing
caga
PostPosted: Wed Sep 29, 2004 12:42 pm     Reply with quote
1. PCM vs. 3.200 is the first one is the new 3.2xx series.
It could easily have a bug that is causing your problem.
2. You don't have a "big array". You have 8 arrays of moderate size.
One thing you might do, is to help the compiler with allocating
the ram. You can use the #locate directive to do this. Example:
#locate lcd_ram1 = 0x110
#locate lcd_ram2 = 0x12C
#locate lcd_ram3 = 0x148
#locate lcd_ram4 = 0x190
#locate lcd_ram5 = 0x1AC
#locate lcd_ram6 = 0x1C8
#locate lcd_ram7 = 0x0A0
#locate lcd_ram8 = 0x0BC
3. Look at this section in the 16F877 data sheet:
FIGURE 2-3: PIC16F877/876 REGISTER FILE MAP
All of your ram variables have to fit into those four ram banks.
Notice how the ram banks have different sizes. You have to pick
locations for your arrays that will fit into the given banks, and
also allow the compiler some room to fit the other variables
into the remaining space.
4. Try not to use #locate in the common RAM area at 0x70-7F
(and also the corresponding addresses for banks 1-3) because
the compiler likes to use this area. Also avoid using 0x20-0x2F
for the same reason.
cagacug
bingo!
PostPosted: Wed Sep 29, 2004 1:05 pm     Reply with quote
Thats exactly the solution, thank you! Wink
This shows to me not to trust much to the compiler's allocation!!!
Alex
PostPosted: Mon Oct 04, 2004 8:50 am     Reply with quote
Don't you have to switch between banks when you use the #locate in different banks ?
PostPosted: Mon Oct 04, 2004 10:15 am     Reply with quote
No.
That is part of the 'point' about *=16. Once this is set as a preprocessor directive, the compiler uses a 16bit address for the RAM. It then automatically switches banks as needed. You could, if you wanted just to store a single array in one of the higher banks, not bother to use this directive (which would then limit all the compilers 'own' accesses to the bottom bank), and manually switch banks yourself, for the accesses needing the higher bank(s) (and switch back as well). The advantage of this is that the main code would be quicker and smaller without the bank switch instructions.
