Pointers to an array
Alex
PostPosted: Wed Sep 29, 2004 7:58 am     Reply with quote
when I pass an array to a function
func(array);
I the any difference if I get it in the function that way:
void func(*array[])
or this: void func(*array)
in other words, is there any defference whether I use the square brackets or not?
Thank you
PostPosted: Wed Sep 29, 2004 12:12 pm     Reply with quote
When you have this type of question, you should make a test program,
compile it, and look at the .LST file.
For example, here is a test program for your question.
Compile it and look at the .LST file.
#include <16F877.H>
#use delay(clock = 4000000)
void func1(char *array[])
char c;
c = array[0];
void func2(char *array)
char c;
c = array[0];
char array[10];
func1(array);
func2(array);
