YulL
Joined: 29 Sep 2004 Posts: 39 Location: Paris (France)
always +2V on my RC7/RX Pin??? |
Posted: Wed Sep 29, 2004 9:03 am |
Is it normal : +2V on RC7 with PIC16F873???
It is connected to my MAX232 on the R2out Pin (9) |
Re: always +2V on my RC7/RX Pin??? |
Posted: Wed Sep 29, 2004 9:22 am |
YulL wrote: | Is it normal : +2V on RC7 with PIC16F873???
Simple answer.
No.
This input is a Schmitt input, so requires to be driven to 0.8*Vdd, to be seen as 'on'. The Max232, normally happily does this. Disconnect the pin from the track (if the chip is socketted, bend it out), and verify the voltage on the pin, and on the socket. It sounds as if something else is shorting the pin, preventing it being pulled properly up, or as if your software is not configuring the pin properly, and it is trying to operate as an output, or that the MAX232, is not receiving it's 5v supply.
asmallri
Joined: 12 Aug 2004 Posts: 1635 Location: Perth, Australia
Posted: Wed Sep 29, 2004 9:28 am |
The PC received data from the PIC so the problem will not be the 5 volt supply. It is most likely two outputs driving in opposite directions |
Posted: Wed Sep 29, 2004 10:29 am |
asmallri wrote: | The PC received data from the PIC so the problem will not be the 5 volt supply. It is most likely two outputs driving in opposite directions |
Don't be quite so sure about this. :-)
I have seen exactly this behaviour, when a designer had connected the MAX232, to 3.3v, instead of 5v, it ran for transmit, but gave a very low receive voltage. This is why I suggested the possibility...
However I see in another thread, that the poster has traced it to incorrect wiring round the MAX232 itself.
