Unused ADC pins
john66
Unused ADC pins
PostPosted: Sat Oct 16, 2004 10:25 am     Reply with quote
I am debugging someone else's design using the PIC16C73. Port A is set up as all analog but there are three unconnected pins on the port. I have seen unconnected digital inputs create nasty, intermittent problems.
Has anyone experienced the same type of trouble with unconnected ADC inputs?
Re: Unused ADC pins
PostPosted: Sat Oct 16, 2004 3:09 pm     Reply with quote
I don't think this would be a problem.
The problem with digital inputs, is they get into the 'transition' area, where they are undecided about whether to be high or low, and can draw excessive current in this area. This is why the act of selecting the ADC, turns off the digital input buffers on the selected pins. The pins are still protected by the clamp diodes, so should be OK. Personally, I'd still clamp the pins, but the normal digital problems should not apply.
PostPosted: Sat Oct 16, 2004 3:44 pm     Reply with quote
That makes sense. Thanks.
Unused pins in general
PostPosted: Mon Oct 18, 2004 12:05 am     Reply with quote
OK, I'll bite: what should one do with unused digital I/O pins? Make 'em inputs and set 'em high? Make 'em outputs and leave them unconnected?
Haplo
Re: Unused pins in general
PostPosted: Mon Oct 18, 2004 12:23 am     Reply with quote
How about making them outputs and setting them high? Very Happy
That's probably the best way of doing it, making them outputs and setting them either to high or low. Or you can make them inputs and tie them to VCC or GND via resistors.
