Joined: 07 Dec 2004 Posts: 127 Location: Southampton, UK
Compiler bug with setup_adc_ports in v4.109
Posted: Tue Aug 03, 2010 8:52 am
Hi all,
I just thought I would show you something that seems to be a bug. I suppose it doesn't strictly count as a compiler bug as it is with one of the supplied functions, setup_adc_ports();
The problem is that on an 18F87J11 (80 pins and includes port H) I want to use H7 as an input but it was always reading zero despite having turned off all the additional pin functions. I was using:
setup_adc_ports(NO_ANALOGS);
Expecting this to set all ANx pins to be digital IO but it misses H7. Here is the listing of what it does including my interpretation:
Work = 0xff
.................... setup_adc_ports(NO_ANALOGS);
1945A: BSF FC0.4 - Set the ADSHR bit to 1 accessing ANCONX not ADCONX
1945C: MOVWF FC1 - Move 0xFF to ANCON0 setting all pins to digital IO
1945E: BCF FC0.4 - Clear the ADSHR bit to 0 accessing ADCONX not ANCONX
19460: BCF FC2.6 - Set -Vref = AVss
19462: BCF FC2.7 - Set +Vref = AVdd
19464: BSF FC0.4 - Set the ADSHR bit to 1 accessing ANCONX not ADCONX
19466: MOVF FC2,W - Move the ANCON1 register to work (ANCON1 = 0x00 on POR)
19468: ANDLW 80 - Work AND 0x80 (0x00)
1946A: IORLW 7F - Work OR 0x7f (0x7F)
1946C: MOVWF FC2 - Put the work register back into the ANCON1 register (Sets ANCON1 0x7F from POR leaving AN15 as analogue)
1946E: BCF FC0.4 - Clear the ADSHR bit to 0 accessing ADCONX not ANCONX
So ANCON1 gets set to 0x7f from the power up value of 0x00 which leaves pin H7 (AN15) as an analogue input (bit 7 is set to 0) rather than digital IO (bit 7 set to 1).
Please let me know if you think I have got this right. I have not looked into it any closer, I just wrote my own setup_a2d_ports function.
Cheers
Ed
mkuang
Posted: Tue Aug 03, 2010 9:59 am
Looks like you are right.
EdWaugh
Posted: Tue Aug 03, 2010 10:04 am
Thanks!
I guess I should submit it as a proper bug report.
