aaron
18F452 SPI DEBUG problem |
Posted: Tue Sep 21, 2004 11:05 am |
Hi folks,
Something realy strange happens when I run the PIC code without the debugging cable. The PIC talks SPI as a slave with another processor (master) and everything goes fine if the debug cable is plugged in. If I recompile the code without the DEBUG and program it into the PIC it looks like the PIC is able to just receive data but it stops sending. Not a single line of code is changed. If I scope the data out line all I see is a big flat line. Nothing.
Any ideas ? Has anyone seen anything like this ?
On the PIC errata they talk about some issues with the MSSP hardware but I don't think is the case.
Any clues about what is going on ? Same code works with the debugger and doesn't when the code is programmed into the target.
Thanks.
Here is my setup:
CCS PCH C Compiler, Version 3.186, 18728
Debugger : MPLAB ICD2
Config code:
#include <18F452.h>
#device *=16
#use delay(clock=40960000)
#fuses H4,PUT,STVREN,NOWDT,NOLVP,NOBROWNOUT,CCP2C1,NODEBUG
#use fast_IO(A)
#use fast_IO(B)
#use fast_IO(C)
#use fast_IO(D)
#use fast_IO(E)
I configure the SPI by writting directly to the registers:
SSPSTAT = 0x00; // SSPSTAT: SMP=0, CKE=0, D//A=0, P=0, S=0, R//W=0, UA=0, BF=0
SSPCON1 = 0x24; // SPI slave mode, clock = SCK pin, /SS pin control enabled
Posted: Tue Sep 21, 2004 11:26 am |
The first question is, have you been able to make any program
work in stand-alone mode ? Or is it just this one program that doesn't
work ? |
aaron
Posted: Tue Sep 21, 2004 11:52 am |
Yes. My program runs ok. The ONLY issues is the SPI traffic from PIC to the other processor. Nothing goes out. Everything else seems to work fine. |
Posted: Tue Sep 21, 2004 12:24 pm |
I don't have PCH 3.186, so I used vs. 3.188. Also, my test board
has a 18F458 on it, instead of a 18F452, but they are similar chips.
I made the following simple test program, and it works.
The PIC puts out groups of pulses on the SCK and SDO pins.
I suggest you try this program. Change the preprocessor
statements as required, to match your hardware.
It should work. If your own program doesn't work, then
post a test program, similar to the one I've done below,
but with the methods that you're using. ie., #fast_io,
PLL x 4 oscillator mode, etc. What I will be looking for
is things like the proper set_tris_c() statement, proper
declarations of register addresses by use of the #byte
statement, etc. So make sure you post a full test
program, and not just code fragments.
Code: | #include <18F458.h>
#fuses XT, NOWDT, PUT, PROTECT, NOLVP
#use delay(clock = 4000000)
#use rs232(baud = 9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
printf("Start\n\r");
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16);
spi_write(0x55);
delay_us(100);
Posted: Tue Sep 21, 2004 1:17 pm |
The code listing that you posted is very simple and indeed it should work. Is simple because the PIC is configured as a MASTER.
In my case the PIC is configured as a SLAVE but when it has something to send over SPI "acts" like a MASTER. As I said the SPI is used for inter-processor communication. The bus access is guarded by a flip-flop and each processor has a line out to signal a new message. |
Posted: Tue Sep 21, 2004 1:28 pm |
Well, if you want me to work on it, you'll have to post a
small test program. |
