Does anybody have any code to share on creating a bootloader for the 18F6720?
___________________________
Original Post ID: 11930
Michael Thompson Guest
Re: Bootloader for 18F6720?
Posted: Fri Feb 21, 2003 8:41 pm
:=Does anybody have any code to share on creating a bootloader for the 18F6720?
Rocco,
I would recommend the bootloader that can be downloaded from Microchips website under Application Note AN00851. It is for the 16F and 18F series of chips. I have been using it for the 18F8720 and it seems to work the best of all of the Microchip tools for the 18F8720 and it is the free one! The PC side of the bootloader is written in Visual Basic and all of the code and project files are included so that one can customize it. The bootloader itself is also easy to modify.
Regards,
Mike
Original Post ID: 11991
rocco Guest
Posted: Sat Feb 22, 2003 6:04 pm
:=:=Does anybody have any code to share on creating a bootloader for the 18F6720?
:=Rocco,
:=I would recommend the bootloader that can be downloaded from Microchips website under Application Note AN00851. It is for the 16F and 18F series of chips. I have been using it for the 18F8720 and it seems to work the best of all of the Microchip tools for the 18F8720 and it is the free one! The PC side of the bootloader is written in Visual Basic and all of the code and project files are included so that one can customize it. The bootloader itself is also easy to modify.
:=Regards,
:=Mike
Thanks, I'll give it a try. Any special things to look out for?
Thnx,
R
Original Post ID: 12023
