Davng
| Void() in a structure |
Posted: Fri Sep 10, 2004 8:48 am |
Why I can't use this piece of code?
typedef const struct _rom_desc_tsk
unsigned char prioinit;
unsigned int stackAddr;
void *nParameters; // Unknown type!
unsigned char futur_use;
unsigned char id_tch;
unsigned int ctx_tch;
} rom_desc_tsk;
The compiler don't let me use a void pointer inside the structure! The error that show me is: "unknown type"
thnx in advance
davng |
| Re: Void() in a structure |
Posted: Fri Sep 10, 2004 10:21 am |
| Davng wrote: | Why I can't use this piece of code?
} rom_desc_tsk;
thnx in advance
davng |
I'm not suprised.
'void' has two different meanings. The first is effectively a 'null' defintion for data types (as in a function that returns nothing). The second form, _was an extension to C, that is part of the ANSI definitions_, where it replaces 'char *', as the generic data pointer. CCS C, _is not ANSI C_. It retains the original K&R defintions, where char * is the generic pointer.
Some 'ANSI like' forms are allowed in places, but most are dubious, and should be used with care...
Basically you are trying to use an ANSI C structure, in a C that does not relibly support this.
Change it to char *, and cast it to the type that is actually required, when accessed.
