Debugging error on PIC16F639 with internal oscillator
Kasper
PostPosted: Fri Jan 06, 2006 1:47 pm     Reply with quote
Hi.
This is my first time using a PIC with the internal oscillator. I have configured the PIC 16F639 to run with an internal 1MHz clock, which, just to test it, I made flash a LED. I can compile and program this to the chip using my ICD2 as a programmer. The chip behaves as I would expect it.
Selecting the ICD2 as a debugger, I get the
"ICD0083: Target not in debug mode, unable to perform operation"
error. I remember getting this back in the days with a faulty external crystal, but now I am using the internal oscillator. Is there anything special I have to do to make the ICD2 work ?
the programming cable is no longer than the one that came with the ICD ( ca. 20 cm)
I have the fuses set as follows:
#device ICD=TRUE
#FUSES INTRC_IO //Internal RC Osc, no CLKOUT,  RA5 and RA4 are IO's no external Clock.
the program is just toggeling a pin for a LED, I can post it aswell, but it works fine when programmed and run without the debugger.
Thanks in advance
Kasper
PostPosted: Fri Jan 06, 2006 2:02 pm     Reply with quote
The 16F639 requires a special header, p/n AC162066, to do debugging
with the ICD2. See page 2 of this Microchip document:
http://ww1.microchip.com/downloads/en/DeviceDoc/ICD2_Header_51292L.pdf
Are you using this header ?
Kasper
PostPosted: Fri Jan 06, 2006 2:41 pm     Reply with quote
They have got to be kidding.. how in the world would they imagine anyone developing or the 16F639 if there is no way to debug it in circuit, with the low frequency front end enabled :(
From this, no, I am not using a special header, I am using the 20 pin 16F639 on a prototype board of our own design, and really, being a small surfacemount chip, this header would never work on my board.
I guess I will have to somehow make a serial output to windows terminal to see what is going on internally... man this sucks :(
Thanks for your reply PCM Programmer, as usual you were right on the money Smile
