Const Array
Andreas
Const Array
PostPosted: Sat Sep 04, 2004 7:11 am     Reply with quote
Hi All,
reffering to my post about the same subject, I found now a workaround.
If You declare a "const char XXX[10][27]" String Array than it will work,
If You want to make it 28 Byte Strings then it will not work.
Will be very interesting what the guys of CCS are telling about this Bug !!
best regards
Andreas
bdavis
PostPosted: Sat Sep 04, 2004 9:04 am     Reply with quote
I am using version 3.202 of the CCS PCWH compiler and it works for a PIC18F452...
