ralpok
PWM Help!!! |
Posted: Wed Jan 10, 2007 10:48 am |
I can't get anything to show up on the CCP1 pin when I configure it as a PWM. Here is the code that I use for a PIC18f4685. Does this code look right?? any suggestions for where problems might be? Thanks in advance!!
#include <18f4685.h>
setup_timer_2(T2_DIV_BY_16, 7, 1);
set_pwm1_duty(16);
setup_ccp1(CCP_PWM);
