Can EX_Tones.c run on 4MHZ clock?
Victor
PostPosted: Fri Dec 31, 2004 7:06 pm     Reply with quote
I modified ex_tones.c to run on 16F627A, and using it's 4Mhz INTRC. However, the frequency is not playback correctly. Is it possible to run this example in 4Mhz clock?
Thank you Smile
PostPosted: Sat Jan 01, 2005 7:39 am     Reply with quote
Is the a few precent off, or way off? If it is only a few percent it is probably the error of the internal RC clock. There is no fundamental reason it can't run at 4MHz.
Sherpa Doug
Victor
PostPosted: Sat Jan 01, 2005 8:15 pm     Reply with quote
The frequecy is totally out initially. After I change the error correction
total_delay_time = (1000000/frequency)/2-316;
It play correctly from octave0 C-note[0] to octave2 G-note[2] only. At octave2 G Note, total_delay_time become negative value after minus of 316. Sad
How to fix this problem and make it play up to octave 3?
Thank you. Smile
#include <16F627A.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP
#define TONE_PIN  PIN_B0
//         NOTE                 FREQUENCY
//                Octave0  Octave1  Octave2  Octave3
const long C[4]  ={ 262,     523,    1047,    2093};
const long Db[4] ={ 277,     554,    1109,    2217};
const long D[4]  ={ 294,     587,    1175,    2349};
const long Eb[4] ={ 311,     622,    1245,    2489};
const long E[4]  ={ 330,     659,    1329,    2637};
const long F[4]  ={ 349,     698,    1397,    2794};
const long Gb[4] ={ 370,     740,    1480,    2960};
const long G[4]  ={ 392,     784,    1568,    3136};
const long Ab[4] ={ 415,     831,    1661,    3322};
const long A[4]  ={ 440,     880,    1760,    3520};
const long Bb[4] ={ 466,     923,    1865,    3729};
const long B[4]  ={ 494,     988,    1976,    3951};
void do_delay(int ms_delay, int num_ms, int us_delay, int num_us)
 int i;
 for(i=0;i<num_ms;i++)
  delay_ms(250);
 delay_ms(ms_delay);
 for(i=0;i<num_us;i++)
  delay_us(250);
 delay_us(us_delay);
void generate_tone(long frequency, long duration)
   int32 total_delay_time;                      // in microseconds
   long total_ms_delay_time, total_us_delay_time;
   int num_us_delays, num_ms_delays, ms_delay_time, us_delay_time;
   long num_periods;
//   total_delay_time = (1000000/frequency)/2-10; // calculate total delay time (10 for error)
   // By changing error to 316, it play correctly from C_note[0] to G_note[2] only
   total_ms_delay_time = total_delay_time/1000; // total delay time of ms
   num_ms_delays = total_ms_delay_time/250;     // number of 250ms delays needed
   ms_delay_time = total_ms_delay_time%250;     // left over ms delay time needed
   total_us_delay_time = total_delay_time%1000; // total delay time of us (ms already acounted for)
   num_us_delays = total_us_delay_time/250;     // number of 250us delays needed
   us_delay_time = total_us_delay_time%250;     // left over us delay time needed
   num_periods = ((int32)duration*1000)/(1000000/frequency);
   while((num_periods--) != 0)
      do_delay(ms_delay_time, num_ms_delays, us_delay_time, num_us_delays);
      output_high(TONE_PIN);
      output_low(TONE_PIN);
   return;
    // Octave 2
     generate_tone(c[2],300); //ok
     generate_tone(d[2],300); //ok
     generate_tone(e[2],300); //ok
     generate_tone(f[2],300); //ok
     generate_tone(g[2],300); //ok
     // Octave 2, A_note
     generate_tone(a[2],300); // stuck here, total_delay_time < 0
