How to reduce size pf code please help
PostPosted: Tue Aug 24, 2004 11:54 am     Reply with quote
Dear All,
I'm using in my project a lot of fprintf, however it produce a lot of code making available memory resource to small for my main program. Do you have any other simple idea how to use fprintf but with a smaller size?
It seems that each fprintf is using a huge overhead.
Many thanks for your help
John
rnielsen
PostPosted: Tue Aug 24, 2004 12:08 pm     Reply with quote
If you have multiple fprintf() statements throughout your code it will definately take up a boat load of space. You might want to see if you can make a function that will take care of the fprintf() stuff for you and just pass variables to it. That way you will only have one, or a couple if you still need more than one routine, fprintf()'s.
Ronald
SherpaDoug
PostPosted: Tue Aug 24, 2004 12:11 pm     Reply with quote
Avoid using printf as much as you can. Use puts() and putc() instead.
