Error in new version CCS 2.213
cfernandez
PostPosted: Sat Dec 04, 2004 10:52 am     Reply with quote
In my program I have preproccesor #IF with some condition, example:
#DEFINE __DEBUG__ 1
#DEFINE __DEGUB_EEPROM__ 0
#IF __DEBUG__ && __DEBUG_EEPROM__
In other version this work OK and this new version the compiler tell me the follow:
ERROR 27 ... Expression must evaluate to a constant
I see that the problem is the logical operator &&, This is a bug?
Thank you very much!
PostPosted: Sat Dec 04, 2004 11:37 am     Reply with quote
You have spelled "DEBUG" differently, between these two lines:
cfernandez
PostPosted: Sat Dec 04, 2004 11:40 am     Reply with quote
Dear PCM
This is a write error in this topic.
#DEFINE __DEBUG__ 1
#DEFINE __DEBUG_EEPROM__ 0
The error is the same
Re: Error in new version CCS 2.213
PostPosted: Sun Dec 05, 2004 2:21 am     Reply with quote
cfernandez wrote:
#DEFINE __DEBUG__ 1
bug ! Confused
wrokaround: use '|' instead of '||' fix my problem
wrokaround: use '&' instead of '&&' best wishes
