donomark Guest
Looking for Graphic LCD demo code |
Posted: Sun Apr 20, 2003 11:28 am |
I want to start using graphic LCD displays in my projects.
Does anybody have some demo code for graphic lcd?
I have not chosen the display type so, at this time, codes for every kind of lcds (based on KS0108 ,T6963C and SED1330 ) are really appreciated.
Best regards.
___________________________
Original Post ID: 13832 |
Shane Rowell Guest
Re: Looking for Graphic LCD demo code |
Posted: Mon Apr 21, 2003 1:13 am |
I have written code to implement graphics and text on the SED1330 on a 320x240 display. The largest task is to understand the setup of the SED1340. I would sugest reading through the datasheet and paying most attention to the system set command. After you understanding the desired setup, I implemented my code on a PIC16F877 using PORT D. When using graphics you must be concerned with the large amount of memory that is required to store the images. I ended up comming up with a compression of my own to allow me to store screens in 26LCxx devices.
If you drop me an e-mail, I would be willing to give more details.
Shane
:=I want to start using graphic LCD displays in my projects.
:=Does anybody have some demo code for graphic lcd?
:=I have not chosen the display type so, at this time, codes for every kind of lcds (based on KS0108 ,T6963C and SED1330 ) are really appreciated.
:=Best regards.
Original Post ID: 13854 |
Silvio Guest
Please, can you code for microchip LCD 320x240 |
Posted: Wed Aug 18, 2004 11:37 am |
Please, can you code for microchip LCD 320x240. I´m with very dificulty Thank |
