SPI to get data from compass
PostPosted: Fri Aug 11, 2006 1:19 pm     Reply with quote
I can't get data from the compass:
What I got are:
X=0
Y=0
Can anybody help?
I am new to PIC
Here is my code:
#include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use delay(clock = 4000000)
#use rs232(baud = 9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
unsigned int   xdata,ydata,hdg_data;    //8-bit unsigned data type
#define _cs      PIN_B1         //Active Low
#define ser_out   PIN_C5
#define ser_in   PIN_C4
#define clk      PIN_C3
//******Initialization********
void init(void)
   output_high(_cs);
   delay_us(1);
   output_low(clk);
   delay_us(1);
   output_low(ser_out);
   delay_us(1);
   output_low(ser_in);
   setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16);
//*******Get xdata**************
void get_xdata()
   output_low(_cs);
   delay_us(1);
   output_high(clk);
   delay_us(1);
   spi_write(0x0B);
   delay_us(100);
   spi_write(0x0C);
   delay_ms(20);
   xdata=spi_read();
   delay_us(100);
   output_low(clk);
   delay_us(1);
   output_high(_cs);
   delay_ms(10);
   printf("\n\rX: %u\n\r",xdata);
//*******Get ydata**************
void get_ydata()
   output_low(_cs);
   delay_us(1);
   output_high(clk);
   delay_us(1);
   spi_write(0x0D);
   delay_us(100);
   spi_write(0x0E);
   delay_ms(20);
   ydata=spi_read();
   delay_us(100);
   output_low(clk);
   delay_us(1);
   output_high(_cs);
   delay_ms(10);
   printf("\n\rY: %u\n\r",ydata);
//*********main***********
main()
   delay_ms(20);
   init();
   get_xdata();
   delay_ms(20);
   get_ydata();
My compass is PNI-V2Xe from PNI corporation.
Connected to PIC as follow:
PNI_SCLK-----------PIC_RC3
PNI_MISO-----------PIC_RC4
PNI_MOSI-----------PIC_RC5
PNI_SSNOT---------PIC_RB1
PostPosted: Fri Aug 11, 2006 1:48 pm     Reply with quote
I didn't look at your code in detail, but your SPI mode is incorrect. The
PNI-V2Xe data sheet shows that the chip operates in Mode 0 (page 18):
https://www.pnicorp.com/downloadResource/c4b6/datasheets/73/v2xebook.pdf
You have it configured for Mode 2. I suggest that you configure the
SPI with the #define statements shown below. Then it's very clear
as to what mode is being used:
#define SPI_MODE_0_0 0x4000
#define SPI_MODE_0_1 0x0000
#define SPI_MODE_1_0 0x0010
#define SPI_MODE_1_1 0x4010
setup_spi(SPI_MASTER | SPI_MODE_0_0 | SPI_CLK_DIV_16);
There might be other problems in your code. I didn't look for more.
PostPosted: Fri Aug 11, 2006 2:14 pm     Reply with quote
I didn't look too much either but if you are using hardware SPI you should not ever have to output_ anything on the CLK line. Its handled by hardware.
I've never put 1us delays in between my CS and data before. Every SPI device I have ever used has had >100nS propogation between CS set asserted and CS hold.
If you were at 80Mhz you might actually need to delay a few cycles.
If you have the time it doesn't hurt to leave it there I guess, but you are only 4Mhz anyway so why bother?
My point of view is from working on mostly time sensitive projects. I usually can not stop what I'm going even for 1uS.
