Clearing contents of an array
herby handcock
PostPosted: Wed Aug 11, 2004 4:14 am     Reply with quote
What is the easiest way of clearing an array used to buffer characters received from RS232. When I fill array with characters I search for a substring then if it is present I want to set array to contain nothing.
Mark
PostPosted: Wed Aug 11, 2004 5:58 am     Reply with quote
memset() would do that for you.
Humberto
PostPosted: Wed Aug 11, 2004 11:55 am     Reply with quote
void clear_array(int Buffer_NAME, int Buffer_SIZE)
int n;
        for(n = 0; n <= Buffer_SIZE; n++)
              Buffer_NAME[n] = 0;
Best wishes,
Humberto
Tom-H-PIC
Ring Buffer
PostPosted: Wed Aug 11, 2004 1:26 pm     Reply with quote
Why don,t you use a ring buffer?
Then you don't have to clear it just get the data out of the buffer.
I use them on all of my serial PIC projects.
Look at CCS examples EX_SISR.C.
Tom
Humberto
PostPosted: Wed Aug 11, 2004 4:46 pm     Reply with quote
herby handcock asked
Ooops, pls change
To:
void clear_array(int *Buffer_NAME, int Buffer_SIZE)
Humberto Embarassed
treitmey
PostPosted: Thu Aug 12, 2004 8:38 am     Reply with quote
Tom-H-PIC: could you post your ring buffer code into the code library? I have used them in the past,... but I want to find out if I'm doing it in the most efficient way. I'll post mine also.
tjr
Neutone
PostPosted: Thu Aug 12, 2004 2:48 pm     Reply with quote
My perference is for linear buffers using an index. When moving data that has a predefined pattern the data can be accessed in the buffer directly rather than indirectly. That makes the code smaller and faster. On the other hand if you are sending or recieving data in a continous stream ring buffers are a better choice. Either way you go you only have to clear the index values not the actual buffer.
