how to use program memory to store and read data?
garyzheng
PostPosted: Wed Jul 28, 2004 2:51 pm     Reply with quote
I use PIC16F873 to design a RF sensors. But the RAM space is to small for application. So i want to use ROM(program memory) for my data storage. But i am confused that what is the difference between read_program_eeprom and read_program_memory?
the follow is some part of my program to read or write program memory:
#ROM 0x0e00 = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}
#ROM 0x0e10 = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}
#ROM 0x0e20 = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}
#ROM 0x0e30 = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}
#ROM 0x0e40 = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}
#ROM 0x0e50 = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}
void read_rom()
int index;
printf("ID Number:");
index=0;
//read_program_memory(0x0e00,tx_buffer,11);
while(index<11)
putc(read_program_eeprom(index+0x0e00));
index++;
void write_rom()
index=0;
while(index<11)
//poll and delay for next character
write_program_eeprom(0x0e00+index,rx_buffer[index]);
// write_program_memory(0x0e00,rx_buffer,11);
index++;
please give me some idea on this topic, thank you:)
Re: how to use program memory to store and read data?
PostPosted: Thu Jul 29, 2004 3:51 am     Reply with quote
void read_rom()
int index;
index=0;
while(index<11)
index++;
void write_rom()
index=0;
while(index<11)
index++;
read_program_eeprom, is the correct/normal call. The latest include files for some procesors, have 'read_program_memory' defined as a 'psedonym' for the other call.
Use the 'eeprom' syntax, since this is portable to the older compilers.
Hopefully you have followed the thread about the limited life of the program eeprom?. It really is not suitable, if the data has to be updated more than very infrequently. Consider an external FRAM instead.
