search string within string
herby handcock
PostPosted: Thu Jul 29, 2004 5:50 am     Reply with quote
I am trying to search a string for another string without any success.
I am using something like:
char mystring[] = "dsdsdswwrgd_ABC_13";
char asp[] = "_B64_";
fprintf(COM1, "%s\n", strstr(mystring, asp));
returns "_ABC_1" where did the "3" go?
herby handcock
RE string within string
PostPosted: Thu Jul 29, 2004 5:52 am     Reply with quote
Sorry, this should have been:
char asp[] = "_ABC_";
rnielsen
PostPosted: Thu Jul 29, 2004 8:20 am     Reply with quote
Try the string function strstr().
ptr = strstr(s1, s2) - Search for s2 in s1.
PostPosted: Thu Jul 29, 2004 9:05 am     Reply with quote
That is what he is allready using.
The problem is not in 'finding' the string, but that the result appears to be truncated.
It is worth looking at 'string.h', since the function defintions are all there. Looking at this, the function walks forward through the first string, looking for the first character in the second string. Once this is found, it goes forward through both strings, and returns the address where the first character was found, when it reaches the end of the second string. As such, it should work.
Verify that the print works correctly with:
fprintf(COM1, "%s\n", mystring);
It may be something more insidious, like the compile dropping the last character of a constant string when loading it to RAM!.
Tell us the compler version (it may be a known problem).
rnielsen
PostPosted: Thu Jul 29, 2004 10:54 am     Reply with quote
DOH! I guess it would help to read through ALL of the text first, eh? *smacks forehead*
PostPosted: Thu Jul 29, 2004 10:59 am     Reply with quote
We have all done it (I usually refer to 'wall-head impact technology testing', when I have been really hard tracking something, and then the 'obvious' error is pointed out in five seconds by someone else... :-)
