EEPROM blanking spontaneously
object01
PostPosted: Fri Jul 16, 2004 3:15 pm     Reply with quote
Working with several PIC18F2320s, I'm finding that the EEPROMs sometimes just go blank. I can't predict when they will or why. Has anyone else had this problem?
Jeff S.
PostPosted: Fri Jul 16, 2004 5:12 pm     Reply with quote
Look at the errata sheet for that chip.
http://ww1.microchip.com/downloads/en/DeviceDoc/80187a.pdf
There's a problem with writing to the data eeprom. It lists a
work-around pertaining to the LVD module. You should write
a small test program that writes to data eeprom and check the
.LST file to see if CCS does the work-around. If not, then add
code to do it. See if that fixes the problem.
object01
PostPosted: Sat Jul 24, 2004 1:09 pm     Reply with quote
The errata characterizes this problem as one of data not being written as expected. I'm working on examining the LVD mechanism in the chip, but my EEPROMs are blanking entirely. One value in particular is never written to while the device is running, and it spontaneously blanks (goes to 0xFF) too.
Are the temperature conditions that can cause this?
Jeff S.
SherpaDoug
PostPosted: Mon Jul 26, 2004 6:47 am     Reply with quote
Is there any chance the PIC is getting hammered with X rays, maybe from a nearby HV arc, or something simillar? Very high temperatures (exceeding the specs) could do this too.
object01
PostPosted: Mon Jul 26, 2004 7:30 am     Reply with quote
It would definitely be a temperature problem, if anything. But I'd have thought being on a car's dashboard on a hot southern day wouldn't exceed the specs.
Jeff S.
PostPosted: Mon Jul 26, 2004 10:40 am     Reply with quote
Jeff S.
Are you kidding!.
I had to do a unit that fits in the top of a truck cab. You are pushing the temperature range, unless you take a lot of care to arrange a method of cooling (for instance, silver foil over the lid of the unit, combined with a heatpipe to the bottom of the vehicle). Why do you think the control electronics on most cars is located on the floor pan?. In direct sunlight, you can boil water comfortably on a metal plate placed under a wind shield, in a much cooler country like the UK...
I'd say there is a 90% chance that heat is the problem.
