newguy
off-topic: 5V single supply rail-rail i/p & o/p op amps? |
Posted: Fri Jul 23, 2004 9:17 am |
The subject says it all. Anyone know of any? Preferably cheap?
I have several automotive sensors that have an analog output, 0 - 5V. I would like to buffer them before they go into the PIC's A/D inputs, mainly because I'd like to have something between the PIC and the outside world to protect the PIC.
I've tried to find suitable single supply op amps, but pretty much every one that I've found won't quite do what I want. As it turns out, the lcd module that I'll be using requires a negative bias, so as a last resort I'm going to use a plain old cheap +/- supply op amp, since I already have a negative supply available. It's just that I'm stubborn, and I really don't want to do it this way!
As an afterthought, does anyone know of a single supply op amp that can be powered from, say 9V, and be able to buffer the 0 - 5V signal that I have? |
drh
Joined: 12 Jul 2004 Posts: 193 Location: Hemet, California USA
Posted: Fri Jul 23, 2004 9:57 am |
Or the MAX4165. Nice if you need quite a bit of drive power.
Charlie U
Joined: 09 Sep 2003 Posts: 183 Location: Somewhere under water in the Great Lakes
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Fri Jul 23, 2004 5:49 pm |
TLC2274 may be a good choice too. |
languer
Posted: Fri Jul 23, 2004 6:35 pm |
Take a look a the OPA340 (single), OPA2340 (dual), OPA4340 (quad) from TI, great little devices. |
Will Reeve
Joined: 30 Oct 2003 Posts: 209 Location: Norfolk, England
Posted: Sat Jul 24, 2004 3:17 am |
For low power I use OPA334 or OPA2334 (2 in 8pin) or OPA4334 (4 in 14pin), my personal favourite!
For a little more "go" I use the TS924 which will drive 80mA into low loads (or should be high loads, low resistances anyway!).
I think a lot of opamp choice comes down to personal preference, there is so many on the market which have very similar specs that when you find one which works well and you know it's parameters you tend to stick with it. I always have a few of the above ready for a quick bread board prototype and they usually end up in the final design!
Keep well,
Will |
