Pilot
ADC using interrupts |
Posted: Sun Aug 01, 2004 11:47 am |
I did 3 channel adc Code: |
#include "C:\PicPrj\CCSC\LCD_I2C_ADC\LCD_I2C_ADC.h"
#include <LCD.C>
// #int_AD
AD_isr()
#define ADCCONST 5.0/1024.0
int i;
float value1, value2, value3;
setup_adc_ports(AN0_AN1_AN2_AN3_AN4);
setup_adc(ADC_CLOCK_DIV_2);
setup_psp(PSP_DISABLED);
setup_timer_1(T1_DISABLED);
// enable_interrupts(INT_AD);
// enable_interrupts(GLOBAL);
lcd_putc("\fLCD Ok!\n");
do {
set_adc_channel( 0 );
value1 = Read_ADC()*ADCCONST;
set_adc_channel( 1 );
value2 = Read_ADC()*ADCCONST;
set_adc_channel( 2 );
value3 = Read_ADC()*ADCCONST;
printf(LCD_PUTC,"\n%4.2f %4.2f %4.2f",value3,value2,value1);
} while (TRUE);
but i want to use interrupt for ADC conversion and dont know how to do it with 3 channels? How i will know which channel is ready for read in the interrupt routine?
Thanks in advance. Ragards. |
Pilot
Re: ADC using interrupts |
Posted: Sun Aug 01, 2004 2:51 pm |
Pilot wrote: | Hi,
I did 3 channel adc
I could do it on my self
Code: | #include "C:\PicPrj\CCSC\LCD_I2C_ADC\LCD_I2C_ADC.h"
#include <LCD.C>
float value[3];
#int_AD
AD_isr()
static unsigned char ch=2;
value[ch] = Read_ADC(ADC_READ_ONLY)*ADCCONST;
printf(LCD_PUTC,"\n%u %4.2f %4.2f %4.2f",ch,value[2],value[1],value[0]);
if (ch==0) ch=3;
set_adc_channel(--ch);
Read_ADC(ADC_START_ONLY);
Read_ADC(ADC_START_ONLY);;
do {
} while (TRUE);
