Einly
How to achieve maximum spi communication speed? |
Posted: Fri Jul 23, 2004 7:52 pm |
Dear all,
I am interfacing AD7716 with PIC16f876. It is a 4 channel adc. Every channel will give 32 bits output. To complete reading the digital output, we have to shift in 32x4 bits using spi communication.
Below is a part of my code:
#use fast_io(b)
//For each channel, I only shift_left 2 bytes since I am only interested in the 2 most significant bytes. After that I just provide 16 clock pulses, without actually reading the data.
for(int i=0;i<16;i++)
output_high(SCLK);
output_low(SCLK);
sheft_left(chan0,2,input(SDATA));
output_high(SCLK);
output_low(SCLK);
output_high(SCLK);
output_low(SCLK);
sheft_left(chan1,2,input(SDATA));
output_high(SCLK);
output_low(SCLK);
output_high(SCLK);
output_low(SCLK);
sheft_left(chan2,2,input(SDATA));
output_high(SCLK);
output_low(SCLK);
output_high(SCLK);
output_low(SCLK);
sheft_left(chan3,2,input(SDATA));
output_high(SCLK);
output_low(SCLK);
#use standard_io(b);
I check with oscilloscope and found out that to shift in all the 4 channels, I need around 340us, means 85 us for each channel.
May I know how can I shorten the time needed to shift all the data? By
1) Using different code?
2) Using hardware spi?
3) Using different PIC microcontroller chip?
4) Using DSP? _________________ Einly |
Neutone
Posted: Fri Jul 23, 2004 8:24 pm |
Change syntax to count down. This;
output_high(SCLK);
output_low(SCLK);
} | Would be faster like this;
for(int i=16;i>0;i--)
output_high(SCLK);
output_low(SCLK);
Shift only one byte at a time.This;
Code: | for(int i=0;i<16;i++)
output_high(SCLK);
output_low(SCLK);
for(int i=8;i>0;i--)
output_high(SCLK);
output_low(SCLK);
sheft_left(chan0hi,1,input(SDATA));
output_high(SCLK);
output_low(SCLK);
sheft_left(chan0lo,1,input(SDATA));
chan0 = make16(chan0hi,chan0lo);
