YUM
SIZE OF A FUNCTION ? |
Posted: Fri Jul 23, 2004 1:04 am |
Does anyone know, how i can determine the size of a function (subroutine) ?
for example:
unsigned char dummy_function (unsigned char uhu)
In the list file i can only see the starting address, but not the end address.
And what, if the function is splitted into blocks by the compiler ?
Haplo
Posted: Fri Jul 23, 2004 1:13 am |
You can see the size of the functions in the statistics file (.sta) if you are using PCW(H). Otherwise you'll need to look into the .LST file. |
SherpaDoug
Posted: Fri Jul 23, 2004 7:08 am |
You could comment it out and see how much ROM usage shrinks.
Note that a function that is never called is usually optimized out of existence. _________________ The search for better is endless. Instead simply find very good and get the job done. |
rwyoung
Posted: Fri Jul 23, 2004 8:10 am |
The end address of a function in the LST file (unless it is for an ISR) will typically end like this:
Code: | 0182: GOTO 29B (RETURN) |
The tip-off is the but the actuall argument to GOTO may vary.
You can then just count words and executions cycles between the start and end of the function.
The statistics file summarizes each function in a table, for example
code]
Page ROM % RAM Functions:
0 16 2 1 @I2C_WRITEU_1_59_60
0 17 3 1 @I2C_READU_1_59_60
0 130 19 0 main
0 90 13 0 Initialize
[/code] _________________ Rob Young
