PIC18F458 - sleep - interrupts - battery
billyboy72
PostPosted: Wed Jul 07, 2004 2:44 am     Reply with quote
Hi to everybody,
I have drawn near from few to the PICs and, as such, I am facing the first problems that I expose You following. My target is to make to sleep the PIC when the power supply falls and to use a battery to keep on developing some activities: particularly if in condition of battery feeding occurs an external interrupts I want to wake up the micro and to write a data in eeprom for then to return in sleep fashions. Obviously to the restoration of the power supply there is the systematic awakening. In order to resolve this last point I connect the Vcc to the pin RB1.
Someone has suggestions
Thanks in advance
Re: PIC18F458 - sleep - interrupts - battery
PostPosted: Wed Jul 07, 2004 6:32 am     Reply with quote
billyboy72 wrote:
Hi to everybody,
Thanks in advance
You need to do more than 'connect the power supply to pin RB1'. This will achieve _nothing_. The 'threshold' voltage for the logic input on this pin, changes as the supply voltage alters, so it'll never trigger. Depending on how much you need to do from detecting a power failure, you can either use the 'brownout' circuit that is inside the chip allready to trigger the code, or (preferably in terms of what can be done), add an external power monitor circuit, like the MAX671, and feed the output of this to the interrupt input. If your supply is being regulated from a higher incoming voltage, consider monitoring this incoming voltage, rather than the 5v rail, since this will give more warning when failure is about to happen.
billyboy72
PostPosted: Wed Jul 07, 2004 7:50 am     Reply with quote
Hi Ttelmah,
thanks for your kind suggestion, I will immediately verify the possibility to insert the suitable IC. Nevertheless I would like to add to the painted scenery in the preceding intervention that I have provided to the input PIN B1 of an opportune passive filter has for avoiding the rebounds of the power supply. Following amount carried over an example of code that reproduces the situation:
// global flag to send processor into sleep mode
short sleep_mode;
short power_down;
int poweroff;
// external interrupt when power supply is switched off
#INT_EXT1
void ext1_isr() {
if(!power_down)
write_eeprom(2,0x0F);
delay_us(10);
write_eeprom(1,0x0F);
delay_us(10);
printf("The processor sleep.\r\n");
++poweroff;
write_eeprom(0,poweroff);
delay_us(10);
ext_int_edge(L_TO_H);
write_eeprom(2,0xFF);
delay_us(10);
write_eeprom(1,0xFF);
delay_us(10);
ext_int_edge(H_TO_L);
printf("The processor run.\r\n");
if(!input(PIN_B0)) /
power_down=TRUE;
delay_ms(100); // debounce button
// main program that increments counter every second unless sleeping
long counter;
byte sleep_status;
byte power_status;
ext_int_edge(H_TO_L); // init interrupt triggering for button press
enable_interrupts(INT_EXT1);// turn on interrupts
printf("\n\n");
counter=0; // reset the counter
poweroff=read_eeprom(0);
if(poweroff==255)
write_eeprom(0,0);
delay_us(10);
poweroff=0;
sleep_status=read_eeprom(1);
if(sleep_status==255)
sleep_mode=FALSE;
sleep_mode=TRUE;
power_status=read_eeprom(2);
if(power_status==255)
power_down=FALSE;
power_down=TRUE;
if(sleep_mode)
sleep();
printf("The count value is: %5ld \r\n",counter);
counter++;
if(counter==10)//
counter=0;//
printf("The eeprom_poweroff value is: %d \r\n",read_eeprom(0));
Thanks in advance
