SHT11 hELP ME
YASAS
SHT11 hELP ME
PostPosted: Tue Jun 29, 2004 4:03 am     Reply with quote
I am undergraduate.
I am currently planning to work on a Project which uses SHT11 humidity sensor.
I hope to modify simple FreeBSD program(DOWN LOADED FROM vitsch.net) with a Sensirion SHT11 to windows platform.
i modify it, but it not work as soon as possible. I sent program with this letter. Please consider my program and explain
Errors of it.(what is the purpose of using (FILE * IO file pointer)).
I got ""Device timed out!!!" error.
Yours,
Yasas
* sensor.c
* Interfacing routines for the Sensirion SHT11 Temperature & Humidity sensor
* Written by Daan Vreeken
* Danovitsch@hotmail.com
* (or Danovitsch@Danovitsch.dnsq.org)
* Published under the terms of the GNU Public License 2.0
* (or any later version)
#include <stdio.h>
#include <dos.h>
//#include <unistd.h>
//#include <err.h>
#define DeviceTimeout 20
#define ReadTimeout 200
void outportb(unsigned short Port, unsigned char Data)
unsigned char D = Data;
__asm __volatile("outb %0,%%dx" : : "a" (D), "d" (Port) );
unsigned char inportb(unsigned short Port)
unsigned char Data = 0;
__asm __volatile("inb %%dx,%0" : "=a" (Data) : "d" (Port) );
return Data;
//pin 14 : out: bit 2 of 0x27a
//pin 15 : in: bit 8 of 0x279
//pin 16 : out: bit 4 of 0x27a
int Data(int Level) {
outportb(0x37a,(inportb(0x37a)&4) + 2*(!Level));
delay(1*1000);
return (inportb(0x379)&8)==8;
void Clock(int Level) {
outportb(0x37a,(inportb(0x37a)&2) + 4*Level);
delay(1*1000);
void Bus_Init(void) {
int Cnt;
//Initiate bus
outportb(0x378,0xff);
Data(1);
Clock(1);
//Connection reset sequence
for (Cnt=0; Cnt<9; Cnt++) {
Clock(0);
Clock(1);
int Bus_Read(unsigned char Command) {
int Cnt;
int Time;
int ReadData;
//Transmission start
Clock(1);
Data(0);
Clock(0);
Clock(1);
Data(1);
Clock(0);
//Send address & command
for (Cnt=0; Cnt<8; Cnt++) {
if (((Command >> (7-Cnt))&1)==1)
Data(1);
Data(0);
Clock(1);
Clock(0);
//ACK
Data(1);
Clock(1);
Time=0;
while ((Data(1)==1) && (Time++<DeviceTimeout))
delay(1*1000);
if (Time>DeviceTimeout)
printf("Device timed out!!!%c\n",0x07);
Clock(0);
//Wait for the SHT11 to get it's data ready
Time=0;
while ((Data(1)==1) && (Time++<ReadTimeout))
delay(1*1000);
if (Time>ReadTimeout)
printf("Measurement timed out!!!%c\n",0x07);
//Now clock 2 bytes of data in...
ReadData=0;
Clock(1);
ReadData<<=1;
if (Data(1)==1)
ReadData|=1;
Clock(0);
//ACK
Data(0);
Clock(1);
Clock(0);
Data(1);
Clock(1);
ReadData<<=1;
if (Data(1)==1)
ReadData|=1;
Clock(0);
//!ACK
Data(1);
Clock(1);
Clock(0);
return ReadData;
#define Cmd_ReadTemp 0x03
#define Cmd_ReadHum 0x05
int main(void)
//FILE *IO = fopen("G:\progport\a\io.txt","r");
int TempData;
int HumData;
float Temp;
float Humidity;
/*if (IO==NULL) {
printf("could not open /dev/io");
Bus_Init();
TempData=Bus_Read(Cmd_ReadTemp);
HumData=Bus_Read(Cmd_ReadHum);
Temp=TempData*0.01-40.0;
Humidity=-4.0 + 0.0405*HumData - 2.8*HumData*HumData/1000000;
printf("temp: %.2f hum: %.2f\n",Temp,Humidity);
//fclose(IO);
return 0;
Paolino
PostPosted: Tue Jun 29, 2004 5:04 am     Reply with quote
Someone did it:
http://www.ccsinfo.com/forum/viewtopic.php?t=17108&highlight=sht11
http://www.ccsinfo.com/forum/viewtopic.php?t=17349&highlight=sht11
Maybe you will find more ideas.
Best wishes.
Paolo.
YASAS
Re: SHT11 hELP ME
PostPosted: Tue Jun 29, 2004 8:42 pm     Reply with quote
Hi all
But I'm try to conectect SHT11 to computer parallel port. I'm never try to connect it to Microcontroller or any athor interface.
so how I generate SCK ,DATA using parallel port
Thank you
jds-pic
PostPosted: Tue Jun 29, 2004 9:20 pm     Reply with quote
is there a method by which we can request that these types of threads be moved out of the code library forum and into the general discussion forum, where they belong?
otherwise, before long the code library forum is going to be filled up with posts like this made by people too lazy to read the the Forum Policy post, which is permanently affixed to the top of the thread listing:
http://www.ccsinfo.com/forum/viewtopic.php?t=19215
jds-pic
YASAS
PostPosted: Tue Jun 29, 2004 9:33 pm     Reply with quote
Sorry about that mistake,
I need some help to connet SHT11 to computer parallel port.
so some one can help me.
yasas
jds-pic
PostPosted: Tue Jun 29, 2004 9:52 pm     Reply with quote
yasas
you are on the wrong forum (this is a code library forum) on the wrong board (this board is for C programming on Microchip PIC embedded microcontrollers), so your chances of getting the assistance you need for connecting this widget to a PC parallel port with a program operating under Windows are exactly nil.
ADMINS -- please move this thread to General!
jds-pic
