iou_82
| Newbie |
Posted: Mon Jun 14, 2004 1:59 am |
I am totally new to this Pic Programming, could anyone please help me, wether where should I begin. I will need to work on the chip 16F877. But I have no idea where to begin.
Please advice on what software should I use.
Thank you |
| Re: Newbie |
Posted: Mon Jun 14, 2004 3:42 am |
| iou_82 wrote: | Hi,
Thank you |
This is a bit like asking 'I want to learn to drive, where should I start'. It is a very open ended question, and one whose answer will depend on what you allready know. You don't say whether you have any other programming experience (once you have learn't one programming language, learning a second one is a lot easier), or whether you have any experience in electronics at all (programming a 'microcontroller', does require some understanding of it's basic operations, if you are not going to waste a lot of time...).
Now the 'chip', doesn't really matter in this regad, since most of the peripheral components are 'common' on the different models in the line. If you were in the UK, and have no programming experience, I'd probably suggest getting one of the basic Magenta PIC tutorial kits, and learning enough about operating the chip, to get you started, using assembler, and only once you can do basic operations with this, consider using a 'high level' language. There are hundreds of books on C' programming (rather than C++). However if you allready have high level experience, then I'd probably suggest going the other way, and getting one of the demo boards, programming a very basic 'hello world' type operation, and then seeing if you can understand how this works from the assembler.
The 'key' with the PIC, is that though the CCS compiler tries to hide the hardware from you (automatically switching the pins data directions etc.), you have to be aware of what is really going on, and that there isn't an 'OS' sitting protecting your work from the vagaries of the hardware.
So (for instance), there was a poster recently, who was having problems sending serial data, while receiving data. The problem here was that on a PC for instance, the 'getc', and 'putc' functions, don't talk directly to the port, but to a relatively large serial buffer, with flow control being operated by the OS for you. Yet on the PIC, these same functions, are talking directly to the hardware, and if a long string is sent, inside the 'receive' handler, received data will then potentially be lost if it arrives while this is going on. So you need to have a very real undertsanding that you are talking directly to the hardware, and the limitations of this.
Posted: Mon Jun 14, 2004 6:04 am |
| jds-pic wrote: |
you can not learn C by looking at an i2c driver.
first, purchase the book "The C Programming Language" by Kernighan and Ritchie. you can get it online for about US$30. this is *the* book when it comes to learning practical C. amazingly, it is not a thick, unwieldy text.
next, write a hello world program in C for your PIC.
then, write a program that stores and retrieves values from a generic i2c EEPROM. this will give you a foundation for the "master-slave" nature of i2c communications.
finally, you can move on to having two pics talk over i2c, with one acting as the master and the other as the slave.
if you are trying to skip directly to the last step, i think you will have a frustrating road. if it's any consolation, i made the same mistake when i learned java -- especially with java's native handling of error conditions. i was in too much of a hurry to bother with learning the fundamentals of throwing/catching exceptions; subsequently, i became increasingly frustrated until i went back and really dug into how it all worked.
all that said, why don't you just connect the your pics with two wires and speak TTL-level serial at 19,200bps between them? debugging is trivial compared to master/slave i2c, and you just need to learn the printf() and getc() functions.
jds-pic |
http://www.ccsinfo.com/forum/viewtopic.php?t=19555&sid=d4d9cda38fc40a4a02d6251e7e70ea06 |
iou_82
| Re : Newbie |
Posted: Tue Jun 15, 2004 2:12 am |
Thanks for the infomation. I dun really have much expereince with C, but i am studying it at the moment. I also have the Hardware ( Pic Programmer - Pic16F84A - 7X16 LED Running Light Signboard ) with me.
I would like to try the ' Hello World ' , would you please post a sample programe that run the ' Hello World ' using C for me to try to download into my Chip. Thanks in advance.
Regards.
Eugene |
Neutone
| Re: Re : Newbie |
Posted: Tue Jun 15, 2004 8:11 am |
| iou_82 wrote: | Thanks for the infomation. I dun really have much expereince with C, but i am studying it at the moment. I also have the Hardware ( Pic Programmer - Pic16F84A - 7X16 LED Running Light Signboard ) with me.
Regards.
Eugene |
Read the manual. All of it. Cover to cover. There is a list of example programms in it. You will find what you are looking for and be better prepaired to solve problems in the future. |
rnielsen
Posted: Tue Jun 15, 2004 8:25 am |
I have found that the best, not necessarily the easiest, way to learn things like this is simply to dive in and start messing around. Pull out the book, read what you can, dig around this forum (doing searches) and start writing your own code. Make it simple at first. Maybe just make an output toggle high and low. Then, print something out on the display. Each time, you'll bang your head against the monitor trying to figure out what you did wrong. When you finally realize what you did and then fix it, you'll most likely remember it from then on. Whereas, if somebody just told you how to do it you'll need to be reminded on how to do it again each time. I know I have a flat forehead from smacking it so much.
Good luck.
Ronald |
iou_82
| RE: |
Posted: Wed Jun 16, 2004 10:12 pm |
Thank for the info, I am getting more familiar with it , I would like to know one more thing is that do I need to use a different version of compiler each time I work with a different type of Chip.
I am currently using 16f84a, which version of compiler should I use.
Thank you. |
Posted: Wed Jun 16, 2004 10:32 pm |
| Quote: | | I am currently using 16f84a, which version of compiler should I use. |
CCS has a page that shows which compiler is used for each PIC.
In the table, "M" means the PCM compiler, "H" means PCH, and
"B" means PCB.
http://www.ccsinfo.com/devices.shtml |
iou_82
| LED |
Posted: Wed Jun 23, 2004 2:29 am |
HI,
I am getting more familiar with the chip 16f84a currently, and using C language to programme it. I would like to know wether is it posible to make the LED - On and Off ' slowly ' , something like DIMMER.
Thank you |
Joan
Joined: 29 May 2004 Posts: 41 Location: Barcelona, Spain
| Re: LED |
Posted: Wed Jun 23, 2004 3:34 am |
| iou_82 wrote: | HI,
Thank you |
Hi iou_82:
you can write a routine for a variable PWM.
Regards;
Joan _________________ I Came. I Saw. I Won. |
iou_82
| RE: |
Posted: Wed Jun 23, 2004 10:14 pm |
HI, Joan
I dun really understand what u mean, can u please advice more.
Thank you
Regards,
Eugene |
| Re: RE: |
Posted: Thu Jun 24, 2004 2:19 am |
| iou_82 wrote: | HI, Joan
Thank you
Regards,
Eugene |
At 'heart', logic outputs on the chips, can only be either 'off', or 'on'. The way to make a light 'dim', is to flash it fast enough that the eye cannot see the flashes. If (for instance), the light is flashed at a rate of 1000 times per second, and at each 'on flash, is turned on for just 1uSec, then this on time is increased steadily over the course of perhaps a second, till at the end of the tme, the light is now 'on' for 999uSec, then the effect will be for the light to brighten over the second. This process of changing a pulse width like this, is called 'Pulse Width Modulation' (PWM).
Many of the larger chips, have 'hardware PWM' circuitry built in, allowing flash rates of many kHz. The 16F84, does not have this ability, but even on these, the processors are so fast (relative to the rate that the human eye can see), that it is possible to generate a 'soft PWM', to give a dimming effect.
Do a seach on PWM', on this group, and you will find hundreds of examples, with some covering the 'soft PWM' approach.
iou_82
| Blinking LED |
Posted: Fri Jun 25, 2004 3:10 am |
Ttelmah,
Thank for the info, I will need to put that as my second assignment.
I am working on 16f628 chip right now, and i have write a simple code to make 1(A) LED blinking and the other 1(B) ON all the time,while (A) is blinking, but when i want to make 2 LED blinking at the same time but at different blinking rate it was not archivable.
What i mean :- (A)LED to blink at 1 SEC Normal blink
(B)LED to blink at 10 SEC Slow blink
(C)LED to blink at 0.5 SEC Fast blink
Is it posible??
Please advice and if posible please provide me with a sample code.
Thank you
Regards,
Eugene |
Joan
| Re: Blinking LED |
Posted: Fri Jun 25, 2004 5:13 am |
| iou_82 wrote: | Ttelmah,
Is it posible??
Thank you
Regards,
Eugene |
Hi io_82:
yes, you can blink 3 led at the same time ... but .... you have 3 solutions:
A) With a soft routine. that means that the only thing that PIC can do ( in essential ) is to generate these blinking.
B) A more acurate solution is to use 3 Timers with their interrupts, but in your case this solution is not possible because F628 doesn't have 3 Timers interrupts, it only have Timer0 interrupt.
C) Configure Timer0 interrupt for 0.25 sec interrupt and use counters for blinking ( Perhaps quite complicated but possible ).
in this case
isr_timer0
if (Counter = multiple of 2)
change state LED_A;
if (Counter = multiple of 4)
change state LED_B;
if (Counter = multiple of 40)
change state LED_A;
counter=0;
You choose ...
Best Regards;
Joan
| Re: Blinking LED |
Posted: Fri Jun 25, 2004 5:16 am |
Is it posible??
Thank you
Regards,
Eugene |
Hi io_82:
in this case
isr_timer0
change state LED_A;
change state LED_B;
change state LED_C;
counter=0;
You choose ...
Best Regards;
