offspr Guest
MAX6662 problem |
Posted: Mon Jun 28, 2004 2:32 am |
I wrote this MAX6662 routine for a PIC16f876A :
Code: | #include <16F876A.h>
#fuses HS,NOPROTECT,NOWDT,PUT,NOBROWNOUT,NOLVP
#use delay (clock=12000000) // 12MHz clock
#use fast_io(a)
// Définition des pins du microcontroleur
#define DQ_PIN PIN_A2 //donnees du MAX6662
#define CLK_PIN PIN_C3 //horloge du MAX6662
#define RST_PIN PIN_A3 //Reset du MAX6662
// write_max6662
// Write a byte to the max6662
void write_max6662(int cmd)
int i;
for(i=128; i>0; i/=2)
output_low(CLK_PIN);
if(i & cmd) {output_high(DQ_PIN);}
else {output_low(DQ_PIN);}
output_high(CLK_PIN);
//output_low(DQ_PIN);
//delay_us(4);
//output_low(CLK_PIN);
//Lecture d'un mot de 16 bits
long temp_data;
long read_temp()
byte j;
output_low(DQ_PIN);
//set_tris_a(0x04); // DQ = input
temp_data = 0x0000;
for(j=0; j<16; j++)
temp_data = temp_data << 1;
if (input(DQ_PIN) )
temp_data |=0x0001; // récuperation du i-eme bit
set_tris_a(0x00); // DQ = output
return temp_data;
long temp;
//init_temp();
output_low(DQ_PIN);
output_low(RST_PIN);
delay_us(1);
write_max6662(0xC1); // lecture de la temperature
temp=read_temp();
output_high(RST_PIN);
printf("%lu\n\r",temp);
I succeed in sending a command to the MAX6662 but when I set the A2 pin as an input, no data come from the MAX6662.
Could someone help me please to correct my mstake.
Thank you |
Posted: Mon Jun 28, 2004 4:51 pm |
Your basic problem is this line right here:
#use fast_io(a)
When you use "fast i/o", you must define the i/o port direction
by using a set_tris_x() statement.
You have some set_tris_x() statements at various places in your
program, but in many cases you are using output_low() or output_high()
without first setting up those pins as outputs.
Because the PIC pins are configured as inputs upon power-up,
you must configure the pins as outputs before using those functions.
(This is only true if you are using the "fast i/o" mode -- which you are).
You need to setup the tris, at the very beginning of main().
Do it before the while() loop. You can change the direction of
the DQ pin later in your program with a set_tris_x() statement,
but you must setup CLK and RST as output pins at the very
start of main(). Note that because these signals are on different
ports, you will need to set the tris for both Port A and Port C. |
