sending DTMF data, please help
runtime
PostPosted: Thu Jun 24, 2004 5:36 pm     Reply with quote
Hello all,
Suppose I want to send the following string of data over a phone line using DTMF tones:
{@ü*38]%<
The hex of each char will be:
7B 40 FC 2A 33 38 5D 25 3C
Using DTMF I can send the tones individually, 7-B-4-0-F-C...
Now, how do I separate each hex digit, i.e: to send digit 7B first i need to send tone 7 and then tone B?
Thank you in advance
Peter
Laurent Chouinard
PostPosted: Fri Jun 25, 2004 10:44 am     Reply with quote
Suppose this:
int8 stuff;
//store 7b in some memory location
stuff = 7b;
//To send the left part:
output = stuff & 0xf0; //This will mask the "b" and keep the "7"
output = output >> 4; // This will shift the 7 from the high nibble to the low
send_dtmf(output); //first byte sent!
//To send the right part:
output = stuff & 0x0f;
send_dtmf(output); //second byte sent!
there you go.
Of course i'm assuming you have a function called "send_dtmf"... adjust for your needs.
