Example for a TC77?
Birdasaur
Example for a TC77?
PostPosted: Fri Dec 12, 2003 6:38 am     Reply with quote
Does anyone out there have a bitbang or SPI_READ() example for a TC77? I've tried the CCS spi_read() calls, but they clock 8 bits, whereas the TC77 temperature register is a 13 bit register. Needless to say a simple read isn't helping me. I've also tried to do a simple bit bang, but its not working. In fact, I can't seem to get the TC77 to even respond using the bit bang. I've posted this question in another thread but it is not getting viewed. I thought maybe it deserved its own thread.
here's some code that DOES NOT WORK Confused
//to try to bit bang the 13 bits
output_low(PIN_B1); //select the TC77
for(i=13; i>0; i--)
delay_us(10);
output_high(PIN_B2);
delay_us(10);
if (input(PIN_B3))
bit_set(data,i);
delay_us(10);
output_low(PIN_B2);
delay_us(10);
output_high(PIN_B1); //deselect the TC77
This code also fails Confused
//To use the spi_read() function
temp1 = spi_read(0x00); //Read the 8 MSB of the data
temp2 = spi_read(0x00);
For the SPI_READ() code I've tried all manner of combinations of reads and writes and all return goofy results. I must be missing something simple, could somebody out there just point me back in the right direction?
Birdasaur
:grin: The Solution
PostPosted: Fri Dec 12, 2003 8:35 am     Reply with quote
Here's the code that works like a dream. Turns out I had a couple jumpers interfering with my bitbang lines. (duh Embarassed )
Also I had the clock order wrong, gotta lower the clock, than raise the clock BEFORE the data bit is clocked out.
I don't know how much of each delay is needed.
data = 0;
F = 0;
for(i=13; i>0; i--)
output_high(PIN_B2); //clock
delay_us(10);
output_low(PIN_B2);
delay_us(10);
if (input(PIN_B3))
bit_set(data,i);
data >>= 6; //to get rid of the fraction of a degree
F = (unsigned int16) (1.8 * data) +32;
printf("\r\nThe temperature is: %lu C/%lu F \r\n",data,F);
Good luck to everyone, I hope this helps someone.
wedilo
PostPosted: Mon Dec 15, 2003 2:58 am     Reply with quote
Hi Birdasaur,
fine code snippet. Thank you...
BUT, in your first post you ask for some code and in your second post you give the answer yourself? Amazing... Laughing
73 Sven
Birdasaur
well....
PostPosted: Mon Dec 15, 2003 10:17 am     Reply with quote
I try to contribute to the forum whenever I can. I've asked for a lot of help in the past and I want to be the "helper" too.
Also, noone answered me so I figured it was a mystery.
It was easier than I thought too.
Good luck everyone.
Cool
wedilo
PostPosted: Tue Dec 16, 2003 1:50 am     Reply with quote
Hello Birdasaur,
that's a great attitude.
Thank you and all the best
73 Sven
>>TechDesign
tc77
PostPosted: Sun Jun 20, 2004 7:38 am     Reply with quote
this one works too! (on a 16f877)
i took these non-standard pins, cause i need RC3 & RC4 for i?c routines..
#bit TC77_CS  =pb.7   // RB7 pin40,TC77 !CS
#bit TC77_SIO =pb.6   // RB6 pin39,TC77 S I/O
#bit TC77_SCK=pb.5   // RB5 pin38,TC77 SCK
void tc77_read(void);
int16 t_in;
void main(){
tris_pb=0x51;      // oiox xxxx
TC77_CS=1;       //
tc77_read();
lcd_gotoxy(90,0);                        // my own routines to display t_in
printf(lcd_text,"%lx",t_in);            // id.
} //end while
      } //end main
void tc77_read(){
char b;
t_in=3;
TC77_SCK=1;
TC77_CS=0;
for(b=16;b!=2;b--){
     TC77_SCK=0;
     TC77_SCK=1;
     if (TC77_SIO){
         bit_set(t_in,b-1);
TC77_SCK=0;
TC77_CS=1;
// so there's no need for long delays at all!! But please do put an elco of 10?F/16V AFTER the voltage regulator. The AD-conversion inside the TC77 needs it!!
