		| Author | Message |
		| micman Guest
				| Circular buffer for STA013 |
				|  Posted: Mon Jun 21, 2004 10:14 am |   |
				| Hi all, I have a problem with circular buffer.
 I work with a pic18f8720 at 20MHz, an interface atapi and sta013 decoder a MPEG.
 I only have a buffer of 2048 byte "int8 mp3data[2048 ]" and I can read byte for byte for "mp3data" and send to STA013 when data request is set.
 The problem is: Where reload data to buffer "mp3data".
 I've a function  "ata_read_sector(0,g,mp3data);" return 512byte data to mp3data
 The code example is inclomplete becose i don't write code for circular buffer!
 The music load is only 64Kbps!!!
 Thank for help me!!
 int32 g;
 int8 mp3data[2048];
 int16 mp3ptr,bufptr;
 g = 48119;  //Sector where there is gives data mp3
 mp3ptr=0;  //pointer read
 bufptr=0;   //pointer write
 ata_read_sector(0,g,mp3data);  //read sector 512 byte
 g++; //incremento sector
 ata_read_sector(0,g,&mp3data[512]); //read sector 512 byte
 g++;
 ata_read_sector(0,g,&mp3data[1024]); //read sector 512 byte
 g++;
 ata_read_sector(0,g,&mp3data[1536]); //read sector 512 byte
 for(;;){
 while(input(DATA_REQ)){   //STA013 request data!!!
 for(it=7;it<255;it--){
 output_low(SCKR);
 dato = mp3data[mp3ptr];
 output_bit(SDI,((errore>>it)&1));
 output_high(SCKR);
 mp3ptr++;
 if(mp3ptr>=2048) mp3ptr=0;
 //????????????????? Circular buffer??//how to????
 // g++
 //ata_read_sector(0,g,&mp3data[]) //function reload 512 chunk
 }//while
 }//for
		| PCM programmer
				|  Posted: Mon Jun 21, 2004 12:37 pm |   |
				| For sample code on circular buffers, look at the EX_SISR.C example file, in this folder:  c:\Program Files\Picc\Examples
 You will have to modify the code somewhat, because that
 example is for a small buffer (less than 256 bytes), and
 you have a large buffer.   ie., the index values must be
 16-bit for your program, instead of 8-bit as in the example.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
