ADC setup code is strange for 16F877 (PCM 3.202)
PostPosted: Mon Jun 14, 2004 5:36 pm     Reply with quote
PCM vs. 3.202 is doing something weird with the ADC setup functions.
Instead of writing to ADCON0 and ADCON1 as a single byte operation,
the compiler is doing it one bit at a time. This must have something
to do with the major changes that CCS did for vs. 3.200.
What I dislike about this method is that it cycles the Port A pins
through several different modes before they reach the intended mode.
That's just wrong on a philosophical level. It could potentially
cause some problem with external circuits by switching a pin into
a mode that's not intended.
In addition to that, I noticed that the startup code for ADCON1 is
probably incorrect. Traditionally, CCS has initialized Port A as all
digitial. But look at the code right below main(). They're doing
a BSF on bits 0-3 of ADCON1. That sets it to 0x0F, which has AN0
as analog, and AN2 and AN3 as Vref pins. For years, they have
initialized ADCON1 to 0x07 (all digital). Why this change ?
I have to assume it's a mistake.
The code below was compiled for a 16F877 with PCM vs. 3.202:
0000                00293 .................... void main()
0000                00294 .................... {
0004 0184       00295 CLRF   04
0005 301F       00296 MOVLW  1F
0006 0583       00297 ANDWF  03,F
0007 1683       00298 BSF    03.5     // ADCON1
0008 141F       00299 BSF    1F.0
0009 149F       00300 BSF    1F.1
000A 151F       00301 BSF    1F.2
000B 159F       00302 BSF    1F.3     // This should likely be BCF.
0000                00303 .................... int16 result;
0000                00304 ....................
0000                00305 .................... setup_adc_ports(ALL_ANALOG);
000C 101F       00306 BCF    1F.0
000D 109F       00307 BCF    1F.1
000E 111F       00308 BCF    1F.2
000F 119F       00309 BCF    1F.3
0000                00310 ....................
0000                00311 .................... setup_adc(ADC_CLOCK_DIV_8);
0010 1283       00312 BCF    03.5     // ADCON0
0011 171F       00313 BSF    1F.6     //     ADSC0 bit
0012 139F       00314 BCF    1F.7     //     ADSC1 bit
0013 1683       00315 BSF    03.5     // ADCON1
0014 139F       00316 BCF    1F.7     //      ADFM bit
0015 1283       00317 BCF    03.5     // ADCON0
0016 141F       00318 BSF    1F.0     //      ADON bit
The other ADC functions, set_channel() and read_adc(), don't appear
to be affected by these problems.
PostPosted: Tue Jun 15, 2004 1:17 am     Reply with quote
It must be a mistake, indeed. The ADC with 3.202 not works properly.
With a well-tested source code I got 0 for all channels. Downgrading to 3.191 and everything is fine.
PostPosted: Tue Jun 15, 2004 1:26 am     Reply with quote
What PIC are you using ?
PostPosted: Tue Jun 15, 2004 1:46 am     Reply with quote
I have tested this with:
16F877
18F452
12F675
getting the same result. It must be something "orbital" about the new ADC handling style.
Haplo
PostPosted: Tue Jun 15, 2004 4:20 am     Reply with quote
Thanks for sharing this, guys...Yesterday I was thinking about updating my compiler from 3.190 to 3.202 in a 16F877 based project with a lot of ADC code, but thanks to your warnings I'll hold off.
Had I changed it, I would've spent days trying to figure out what was wrong. A broken ADC code is the last thing you expect from the new version of the compiler, afterall.
Kieran
ADC setup and Vn3.202
PostPosted: Tue Jun 15, 2004 4:33 am     Reply with quote
I have just recompiled a project for a 16F876 using ADC and it works fine.
....................    setup_adc_ports(RA0_RA1_RA3_ANALOG);
085B:  BSF    03.5
085C:  BCF    1F.0
085D:  BCF    1F.1
085E:  BSF    1F.2
085F:  BCF    1F.3
....................    setup_adc(ADC_CLOCK_INTERNAL);
0860:  BCF    03.5
0861:  BSF    1F.6
0862:  BSF    1F.7
0863:  BSF    03.5
0864:  BSF    1F.7
0865:  BCF    03.5
0866:  BSF    1F.0
I agree that the code is messy.
Have you reported this to CCS?
PostPosted: Tue Jun 15, 2004 11:45 am     Reply with quote
I agree that the code is messy. Have you reported this to CCS?
Yes, I sent them an email just now.
