howto display a variable on LCD?
Bloobird0
PostPosted: Mon Jun 14, 2004 12:00 pm     Reply with quote
hello all, I use an LCD that works fine for displaying text (common LCD in 4 bit mode).
Nevertheless I would like to display a variable on it but I don't know how.
For example:
lcd_putc("\fTemperature: %i°C"); //test écran LCD
where i is the variable to display (integer).
Can someone help me?
PostPosted: Mon Jun 14, 2004 12:15 pm     Reply with quote
Use the special CCS feature, which allows the output of printf()
to be re-directed to another function. In the example below,
the output of printf is sent to the lcd_putc() function.
The printf function converts the variable 'temperature' into
ASCII characters, so it can be displayed on your LCD.
#include <16F877.h>
#use delay(clock = 4000000)
#include <lcd.c>
signed char temperature;
temperature = -40;
printf(lcd_putc, "\fTemperature: %d", temperature );
Bloobird0
PostPosted: Mon Jun 14, 2004 12:19 pm     Reply with quote
yesss, it works great!!
Thank you for this tip!
