mirberti Guest
change i2c address with software |
Posted: Fri Jun 11, 2004 8:24 am |
I have a 18F458 a microswitch on PORTD.
I wont change the address of I2C via software but the compiler send me an error.
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xb4, fast,FORCE_HW)
How I can change the parameter address ???
Regards Mirko |
Re: change i2c address with software |
Posted: Fri Jun 11, 2004 8:38 am |
mirberti wrote: | Hi,
Regards Mirko |
The line you post should work fine.
It is quite common for error messages to appear on a line, when the fault is actually somewhere just in front of this point. Remember the device selection, and #use_delay declaration need to be before this line.
mirberti Guest
Posted: Fri Jun 11, 2004 8:55 am |
My complete start code is :
#include <18F458.h>
#fuses HS,NOWDT,WDT1,NOLVP
now, if I use this code all is OK but I wont change this code for permit to change my i2c address by a dip-switch.
How can I change it ?
Mirko |
rnielsen
Posted: Fri Jun 11, 2004 9:29 am |
Here is what I have done with one of my projects. The base address of the Slave is 0x90. I use four inputs to modify the address if needed.
#use i2c(Slave,fast,sda=PIN_B1,scl=PIN_B4,restart_wdt,address=0x90)
#byte SSPADD = 0x93 // Slave address register
unsigned int8 slave_addr = 0x90;// base address for all slaves is 0x90
main(void)
get_add();
SSPADD = slave_addr;
*main body*
void get_add(void) // possible combinations
{// base address is 0x90 0x90 92 94 96 98 9A 9C 9E A0 A2 BASE:1001 0000
if(input(PIN_A0)) // 0 1 0 1 0 1 0 1 0 1
bit_set(SLAVE_ADDR, 1);
if(input(PIN_A7))// 0 0 1 1 0 0 1 1 0 0
bit_set(SLAVE_ADDR, 2);
if(input(PIN_A6))// 0 0 0 0 1 1 1 1 0 0
bit_set(SLAVE_ADDR, 3);
if(input(PIN_B7))// 0 0 0 0 0 0 0 0 1 1
bit_clear(SLAVE_ADDR, 4);
bit_set(SLAVE_ADDR, 5);
}// end of get_add()
Posted: Fri Jun 11, 2004 10:04 am |
mirberti wrote: | My complete start code is :
#include <18F458.h>
Mirko |
It is possible that the I2C setup, works like the RS232 one. If so, then this should work:
switch (input & 3) {
case 0:
case 1:
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xb5
case 2:
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xb6
case 3:
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xb7
In the case of RS232, this type of construction had to be used before the seperate baud rate control functions, an 'streams' were introduced, and the compiler applies the last such function 'passed' in the normal flow. Whether this works with I2C, I cannot say for sure. It is worth a try.
However if you want a lot of possible addresses, do a single #use_i2c, with a 'default' address, and use:
#byte I2C_ADDRESS = 0xFC8
I2C_ADDRESS=(0xB0 + input);
Where 'input' is a variable carrying perhaps a three bit address.
mirberti Guest
Posted: Fri Jun 11, 2004 10:08 am |
thanks a lot. I try now youre solution
hi Mirko |
