EEPROM 93C56 16bit support
Post new topic   Reply to topic    CCS Forum Index -> Code Library
sv_shady
PostPosted: Tue Apr 29, 2008 12:25 pm     Reply with quote
This is an enhanced 9356.c file which supports EEPROM Disable Function and 16bit mode of organizing eeprom memory. It is extensively tested and it works fine.
#define EEPROM_SELECT PIN_C7
#define EEPROM_CLK    PIN_C6
#define EEPROM_DI     PIN_C5
#define EEPROM_DO     PIN_C4
#define EEPROM_SIZE    256
void Enable_ext_EEPROM()
   int cmd[2];
   int i;
   output_low(EEPROM_DI);
   output_low(EEPROM_CLK);
   output_low(EEPROM_SELECT);
   cmd[0]=0x80;
   cmd[1]=0x9;
   for(i=1;i<=4;++i)
      shift_left(cmd,2,0);
   output_high(EEPROM_SELECT);
   for(i=1;i<=12;++i)
      output_bit(EEPROM_DI, shift_left(cmd,2,0));
      output_high(EEPROM_CLK);
void Disable_ext_EEPROM()
   int cmd[2];
   int i;
   cmd[0]=0x00;
   cmd[1]=0x08;
   for(i=1;i<=4;++i)
   for(i=1;i<=12;++i)
void write_ext_eeprom(int address, int data)
   int cmd[3];
   int i;
   cmd[0]=data;
   cmd[1]=address;
   cmd[2]=0xa;
   for(i=1;i<=4;++i)
      shift_left(cmd,3,0);
   for(i=1;i<=20;++i)
      output_bit(EEPROM_DI, shift_left(cmd,3,0));
   delay_ms(11);
void write_ext_eeprom16(int address, int16 data)
   int16 cmd[2];
   int i, code;
    code = 0x05;
    cmd[0] = data;
   cmd[1] = make16(code, address);
   for(i=1;i<=5;++i)
      shift_left(cmd,4,0);
   for(i=1;i<=27;++i)
      output_bit(EEPROM_DI, shift_left(cmd,4,0));
   delay_ms(11);
int read_ext_eeprom(int address)
   int cmd[3];
   int i,data;
   cmd[0]=0;
   cmd[1]=address;
   cmd[2]=0xc;
   for(i=1;i<=4;++i)
   for(i=1;i<=20;++i)
      if(i>12)
         shift_left(&data,1,input(EEPROM_DO));
   return(data);
int16 read_ext_eeprom16(int address)
   int16 cmd[2], data;
   int i, code;
   code = 0x06;
   cmd[0] = 0;
   for(i=1;i<=5;++i)
   for(i=1;i<=27;++i)
      if(i>11)
         shift_left(&data,2,input(EEPROM_DO));
   return(data);
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
