Richard Guest
Program will only work in MPLAB simulator |
Posted: Sun Jun 06, 2004 2:06 pm |
Dear PCM users,
I have recently bought the PCM compiler, I am having problem with the following code:
#if defined(__PCM__)
#include <16F874.h>
#device ICD=TRUE
#fuses XT,NOWDT,NOPROTECT,NOLVP,NOPUT,NOBROWNOUT
#include <lcd.c>
int sec=0; //second
int min=0;//minute
int hrs=0; //hour
int milli=0;
int increment = 0;
int flag=0;
int data=0;
void display()
if (flag==1)
lcd_gotoxy(0,1);
printf(lcd_putc,"%02U:%02U",hrs,min);
lcd_gotoxy(1,1);
printf(lcd_putc,"%S",data);
#int_rtcc
void clock_isr()
increment++;
if (increment==2)
{ milli++;
increment=0;
if (milli==10) // 10*100ms = 1second passed
sec++;
milli=0;
if (sec==60) // 60*1sec = minute
sec=0;
min++;
flag=1;
if (min==60)
min=0;
hrs++;
flag=1;
if (hrs==24)
sec=0;
hrs=0;
flag=1;
if (milli < 10) //milli lower than 10 exit after incrementing milli
set_RTCC(60); //setup TMR0 to count upto 100ms
lcd_init();
set_RTCC(60);
setup_counters(RTCC_INTERNAL,RTCC_DIV_256);
enable_interrupts(INT_RTCC);
while (1)
if (flag==1)
display();
flag=0;
The code is for a rel time clock on the LCD (CCS LCD DRIVERS),
the interrupt happens every 49ms - using timer0
When I use MPLAB sim it works as it should, but if i blow it onto the chip I get nothing on the display.
I have tested the LCD, PIC, connectivity.
Can anyone program my code into a PIC or find any mistakes
I hope someone can help |
Richard Guest
Posted: Sun Jun 06, 2004 2:08 pm |
PCM 3.185
I am using the MPLAB ICD2 - MPLAB 6.3
NO COMPILER ERRORS!!! |
Posted: Sun Jun 06, 2004 2:39 pm |
I tested it with PCM vs. 3.188. I changed the printf statements
to send output directly to the PC terminal window, because I don't
have a LCD on my demo board.
I also added one line to your int_rtcc function, so that it would
display output every second, instead of every minute.
That's better for a test program.
Then it worked. It displayed this every second:
00:00
sec++;
milli=0;
flag = 1; // Add this line to get output every 1 second.
Richard Guest
THANKS |
Posted: Sun Jun 06, 2004 3:06 pm |
I have been trying to get this working for the past week
You are truely a PCM programmer
Thank you!!! |
