The first line says that 'value' is an 8 bit integer. The second says that 'pointer_to_value', is a pointer to an 8bit integer (note that the variable itself, will then normally be a 16bit number). Then 'second_value' is another 8bit integer.
Then pointer_to value, is loaded with the address of 'value.
Finally, second_value, is loaded with the contents addressed by 'pointer_to_value'.
