Store/read structure to/from eeprom...
PostPosted: Sat May 29, 2004 9:27 am     Reply with quote
I´m trying to write a struct that will "live" in eeprom, will be loaded from eeprom and stored sometimes.
struct eeprom {
int8 table1[64];
int8 table2[64];
int8 table3[64];
int8 speed;
int8 load; ...
...32 config bytes
struct eeprom config;
where I´m stuck is at using pointers to access data in the struct.
int16 pointer;
for (index=0;index<=160;index++) {
eeprom_write(..config..don´t know how to access); //write or read
delay_ms(10); // let write cycle to end
Darren Rook
PostPosted: Sat May 29, 2004 10:28 am     Reply with quote
how about this:
int8 *pointer;
int8 index;
int8 eeprom_address=0;
pointer=&config;
for (index=0;index<=sizeof(config);index++) {
  eeprom_write(eeprom_address++,*pointer);
  pointer++;
Also, I don't think you need the delay... I think eeprom_write() will wait until the last write cycle ended.
future
PostPosted: Sat May 29, 2004 2:34 pm     Reply with quote
And how about accessing bits individually? like config.speed.bit0..bit7
bit_test(config.speed,0) ?
