I have seen this routine posted several places for debouncing a pin. Its supposed to be a lot faster than using delays to wait for the pin to debounce.
If I was checking my buttons every 10ms (using a timer), will this code work for me- or should I only use it on an interrupt-on-change type button? Any comments on this routine would be great. Thanks.
if(PIN_OVERLOAD) // Test the inputs status at this time
{ if(bit_test(++debounce_counter_OVERLOAD,CounterSize)) // Aproach and test for true status
{ --debounce_counter_OVERLOAD; // Remove counter overflow state
Overload_Alarm=1; // Set true status
} // Make adjustments to the tested bit
} // to change the counter size
else // The input was false
{ if(--debounce_counter_OVERLOAD==0) // Aproach and test for false status
{ ++debounce_counter_OVERLOAD; // Remove counter from zero state
Overload_Alarm=0; // Set false status
I suggest CounterSize = 4; to debounce in 6 passes (60mS at 10mS per pass)
