ibg
| Initialisation array problem |
Posted: Mon May 17, 2004 11:41 am |
I have a problem when I try to initiliase the 'time' field (it's a string) of a struct that belongs to an array.
The problem I got is that when I print 'time' just garbage appear.
The code is the following:
#include <18F452.h> // The device (PIC 18F452) include file
#device *=16 ADC=10
#include <string.h>
#define MAX_FISH_DISPLAYED 3 // The Maximum number of fish entries displayed
#use delay(clock=19660800) // Sets the speed for the PIC (itīs meausured in cycles per second)
#use fast_io(A) // Fast method of doing Input/Output
#use fast_io(B) // The direction register will be set later with the "set_tris_X()" instruction
#use fast_io(C)
#use fast_io(D)
// I/O ports are mapped in memory (Have a look to the Special Function Register (SFR) of PIC18F452)
#byte PORTA = 0xF80
#byte PORTB = 0xF81
#byte PORTC = 0xF82
#byte PORTD = 0xF83
#byte PORTE = 0xF84
// Peripheral Interrupt Request (for TIMER1)
#byte PIR1 = 0xF9E
#use rs232(baud=38400, xmit=PIN_C0, stream=DEBUG)
struct data_fish{
char time[10];
unsigned int32 frequency;
unsigned int pulses;
unsigned long signal_strength;
unsigned int32 time_unit;
char table[3][5]= {'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'I', 'J', 'K', 'L','M', 'N', 'O'};
struct data_fish data_fish_array[MAX_FISH_DISPLAYED];
// Functions used by the main program
void init();
void init_data_fish_array(struct data_fish a_data_fish_array[]);
// Main program
int i, j, k= 0;
int ascii_A= 65;
int ascii_B= 66;
int ascii_C= 67;
int ascii_D= 68;
int ascii_E= 69;
int ascii_to_add= 0;
init();
init_data_fish_array(data_fish_array);
fprintf(DEBUG, "Starting ...\n\r");
for (i= 0; i < MAX_FISH_DISPLAYED; i++)
fprintf(DEBUG, "%s\n", data_fish_array[i].time);
fprintf(DEBUG, "%lu\n", data_fish_array[i].frequency);
fprintf(DEBUG, "%d\n", data_fish_array[i].pulses);
fprintf(DEBUG, "%lu\n", data_fish_array[i].signal_strength);
fprintf(DEBUG, "%lu\n", data_fish_array[i].time_unit);
// Initialisation routine
void init()
// SET_TRIS is necessary when using fast_io (in order to establish the pin direction)
// Remember:
// 1 -> in
// 0 -> out
set_tris_a(0x00); // 0000 0000
set_tris_b(0x00); // 0000 0000
set_tris_c(0x00); // 0000 0000
set_tris_d(0x00); // 0000 0000
// Initialise the array that contains fish data
char the_time[10]= "--:--:--";
int i;
strcpy(a_data_fish_array[i].time, the_time);
a_data_fish_array[i].frequency= 0;
a_data_fish_array[i].pulses= 0;
a_data_fish_array[i].signal_strength= 0;
a_data_fish_array[i].time_unit= 0;
Thanks for your help,
ibg |
Posted: Mon May 17, 2004 12:17 pm |
| Quote: | The problem I got is that when I print 'time' just garbage appear.
strcpy(a_data_fish_array[i].time, the_time); |
Change the function name to "strcopy", and it should work.
strcopy(a_data_fish_array[i].time, the_time);
CCS uses strcopy() to do ram-to-ram copying.
They use strcpy() to copy from ROM-to-ram.
Since your source and destination strings are both in ram,
you must use strcopy. |
ibg
| 'strcopy' doesn't work either |
Posted: Mon May 17, 2004 12:48 pm |
Sorry, but the function 'strcopy' doesn't work either. Any other suggestion?
Thanks,
ibg |
Hans Wedemeyer
| try this |
Posted: Mon May 17, 2004 3:06 pm |
#device *=16 ADC=10
#include <string.h>
#use fast_io(C)
#use fast_io(D)
#byte PORTA = 0xF80
#byte PORTB = 0xF81
#byte PORTC = 0xF82
#byte PORTD = 0xF83
#byte PORTE = 0xF84
#byte PIR1 = 0xF9E
typedef struct {
char time[10];
}data_fish;
char table[3][5]= {'A', 'B', 'C','D', 'E', 'F','G', 'H', 'I','J', 'K', 'L','M', 'N', 'O'};
void init();
void init_data_fish_array(data_fish a[])
char the_time[]={"--:--:--"};
int i;
strcpy(a[i].time, the_time);
a[i].frequency= 0;
a[i].pulses= 0;
a[i].signal_strength= 0;
a[i].time_unit= 0;
// Main program
int i, j, k= 0;
int ascii_A= 65;
int ascii_B= 66;
int ascii_C= 67;
int ascii_D= 68;
int ascii_E= 69;
init();
void init()
// Remember:
// 1 -> in
// 0 -> out
| I still get garbage :( |
Posted: Tue May 18, 2004 3:38 pm |
I have compiled and run the above code and I still get garbage when the time field is printed. Any suggestion about how to fix it?
Thanks,
ibg |
Hans Wedemeyer
| Re: I still get garbage :( |
Posted: Tue May 18, 2004 6:04 pm |
| Anonymous wrote: | Hi,
Thanks,
ibg |
try printing the array as it is initialized, and dump that strcpy:-
int i,j;
for (j=0; j<strlen(the_time) ; j++)
a[i].time[j] = the_time[j];
puts(a[i].time[j]);
a[i].frequency= 0;
a[i].pulses= 0;
a[i].time_unit= 0;
If it prints OK then look for a problem elsewhere. |
| It's working |
Posted: Wed May 19, 2004 11:33 am |
Hej again,
I don't know yet but the 'strcpy' has a weird behaviour and it doesn't work.
Anyway, I copy the string as suggested (going through the different elements of the string) and is working well.
Thanks,
ibg |
